Old 07-18-2014, 05:09 PM   #341
The_Rhino's Avatar
LynnDiesel,
Is there a reason you chose the 3" wide Slick Strips vs. the 12" wide product made by ePlastics?
Your mod looks like the best option for me. Therefore I am getting ready to do this MOD myself & was trying to decide between ordering the 3" wide roll & the 12" wide (which can be ordered by the foot).
2011 RAM 2500 ST Crew Cab 5.7 Hemi ($14K in '13)
2011 Primetime 3150BHD Touring Edition ($20K in '14)
Days camped in 2017-31
2016-36; 2015-37; 2014-31
The_Rhino is offline   Reply With Quote
Old 07-18-2014, 11:09 PM   #342
The Rhino,
I went with the 3" wide x 50 ft roll because I felt this size would be easier to handle, place more accurately and get the air pockets out. The seams are tight and barely noticeable. The price per square foot is about the same. I cut 28" long pieces for the 24" deep sofa/refrig slideout and will cut 40" long pieces on the 36" dining slideout. I used a complete 50 ft roll on each slideout. The surface must be clean and dry. I trimmed the corners of each strip at a 1/8" 45 degree snip, before removing the paper back. I used a 2.5" wide metal paint scraper (pull, do not push) to apply the final pressure to secure the strips. I also caulked the sides of the slideout wall from the metal trim to the edge of the outer strip with black silicone to prevent water from possibly getting under the strip. Good luck and let us know how it performs for you.
2003 F250 7.3 PS CC
2014 Crusader 285RET
LynnDiesel is offline   Reply With Quote
Old 07-24-2014, 08:53 PM   #343
Texas
My 2013 - 295RST - has the same issue on the kitchen slide. Dealer is trying to get an approval to apply tape sealant 1st, then some type of a thin and hard strip over the tape so the guides on the floor would only contact the hard strips.. Will keep you posted.
830hvacman is offline   Reply With Quote
Old 07-24-2014, 10:05 PM   #344
Platokidd's Avatar
I use slide slickers inside,works great with the plastic wear strips so far.
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
nights of camping
2017-67 / 16-92 / 15-73 / 14-60 / 13-33
Seasonal
Old 07-25-2014, 07:32 AM   #345
zs325RES's Avatar
I'm not waiting for PrimeTime to offer any fix, plus my rig is out of warranty now anyway.
The fix I did on my atrium slide has worked out so well (page 10), I did the same on my kitchen slide this week. The only difference was that I raised the room with a jack to get the strip between the rub strip and floor so there is no 'transition' when the room moves in or out. The edges are where the room weight is primarily supported, as evidenced by the pattern of wear on most rigs here. I caught mine before the darco was compromised much and used some sealant between the floor and strip to help keep water out.
It didn't cost me a thing because I had some stuff lying around, and it was not that difficult to do, so Job Done.
I'm really surprised that PrimeTime (others too) let a design like this go to production. Most other things seem to have been thought out better.
2013 Crusader 325RES Touring Edition
2006 Silverado 2500HD LT SW ECSB, 6L LQ4/4L80E 4.10s w/16K Curt slider (not necessary), Air Lift bags & Black Bear Performance tune & CAI
Norm & Karen Zondervan
zs325RES is offline   Reply With Quote
Old 07-25-2014, 01:22 PM   #346
Platokidd's Avatar
zs325RES, did you take any pics of jacking the slide? Could you explain more about how you went about jacking the slide?
nights of camping
Seasonal
Old 07-25-2014, 02:20 PM   #347
zs325RES's Avatar
Sorry no pics, but I used my floor jack (typical). Knowing the support for the room is on the ends by the front and rear walls, I use a ~12" long 2x3 along the bottom side of the floor along the edge under the walls and lifted using another 2x2 board between the jack and the 2x3, just enough (~1/2") for the floor to clear the rub strips. Simple really.
I hope this paints the picture.
Old 07-27-2014, 04:43 PM   #348
Just completed the dining slideout with Slick Strips from elastics.com. I used the 1/32" thick x 3" wide with pressure sensitive adhesive. I put 12" wide at each end and one 12" wide section in the middle. Jacked up the slide 3/4" and used 40" long strips since the slide travels 36". Very smooth operation. Once you press the strips on with pressure, they do not come off.
2003 F250 7.3 PS CC
Old 08-07-2014, 01:16 AM   #349
Texas
Well, so much for it still being in warranty, Purchased it new in April 2013, and now (Aug 2014) Out of Warranty....
Old 08-07-2014, 06:01 AM   #350
Platokidd's Avatar
Did you call pt ?
nights of camping
Seasonal
slide, slide out
