Old 06-06-2017, 01:51 PM   #661
wicked1's Avatar
Originally Posted by Brother Les View Post
there are rollers mounted to the main floor and the slide outs move on these rollers causing wear also.
Ah ok wouldn't think the rollers would scrape up the slide but I guess I will have to see if I can see them without pulling the slide off it's track
2016 F350 Supercew Short Box 6.7 PowerStroke Diesel
2013 Crusader 295RST Touring Edition
wicked1 is offline   Reply With Quote
Old 06-06-2017, 06:51 PM   #662
Texas
Go back to my post #478 with some pictures - This is what I did.
I need to catch up to the new owner to see how its been holding up, now about 3 years later.
Good Luck!!
2015 F350 DRW 6.7 Super Duty, 2015 SOB 5'er w/ G614's and Titan Disk Brakes.
830hvacman is offline   Reply With Quote
Old 06-06-2017, 07:54 PM   #663
wicked1's Avatar
Good Luck!!
That looks like a thick piece of plastic, it did not lift the slide too much to throw it off alignment?
Old 06-07-2017, 10:41 PM   #664
Texas
I did just moved the slide out brackets down 1/4" (The slide is now 1/4" higher) from their original locations, which I marked beforehand..
Thanks,
Ken
Old 06-28-2017, 08:13 PM   #665
Originally Posted by M109Rrider View Post
I made my own slide sliders out of vinyl gutter covers I picked up at Home Depot. I cut flange piece off leaving a flat piece of 1/32" thick vinyl about 6" wide and 4' long. ran 3 strips under my big slide. Works good. Thinking of adding 2 more since the slide is so long.
How is your vinyl holding up? How did you secure them.
2017 Sanibel 3601
2015 F350 - 6.7 Diesel
Retired SMsgt USAF 21 years
6 years weekend camping Class C
2017 camping 20 days and counting
Brand2328 is offline   Reply With Quote
Old 06-28-2017, 08:45 PM   #666
2018 FR 304BS. 3 trips, 12 nights and 5 of the 6 edges are showing wear. Stopped by dealer on way home from last trip...they said they could put some tape it. HA !!! Had also found a 2" cut it the wrap underneath the edge of slide that assemblers used about 20 staples to close. after and hour of digging out staples I discovered the cut was at least 12" wide. Some careful handling and contact cement and you can barely tell it's there.
TheWolfPaq82 is offline   Reply With Quote
Old 06-28-2017, 09:34 PM   #667
wicked1's Avatar
Gorilla Glue makes a black duct tape, works well to cover it up
Old 06-28-2017, 10:22 PM   #668
Yeah ! They do have great tape. Thanks !
Old 07-22-2017, 08:11 PM   #669
sji
We installed the strips that were provided from the factory. Now the outer seal sweep that sits against the vertical side of the slide is ripping from the bottom about 6-8 inches. We ordered the replacement piece ($110 ) and was going to do it myself but then was told by the dealer when it came in the whole slide has to be removed to install it. I have no way to remove the entire slide. Now I noticed the opposing slide is ripping as well in the same spot. I did adjust the slide after installing the repair strips on the underside so it wasn't rubbing and wearing the carpet, but now I have this headache to deal with. Don't have all that much faith in my dealer to install new slide sweeps and adjust my slides without leaving me without further issues.
sji is offline   Reply With Quote
Old 07-23-2017, 06:53 AM   #670
How did you mount the vinyl strip you made?
sk734 is offline   Reply With Quote
Old 07-23-2017, 06:58 AM   #671
How did you attach strip?
Old 07-23-2017, 07:20 AM   #672
M109Rrider's Avatar
Small counter sunk screws. 2.5 years and still working great.
Jason and Billie
2018 F-250, 6.2L
2011 Prime Time Crusader 320RLT
M109Rrider is offline   Reply With Quote
Old 07-23-2017, 09:23 AM   #673
Thanks - sounds good to me.
Old 07-23-2017, 09:56 AM   #674
wicked1's Avatar
Did you have to lift the outside edge of the slide to get them installed or did you put them from the outer edge to the inner edge with the slide all the way out?
Old 07-23-2017, 10:23 AM   #675
M109Rrider's Avatar
With the slide out, I used a bottle jack (with a piece of 2x4 to spread out the weight) to lift the slide a tiny bit. I slipped the end of the vinyl between plastic strip the slide rides on and the bottom of the slide.
Jason and Billie
2018 F-250, 6.2L
Old 07-23-2017, 10:35 AM   #676
wicked1's Avatar
Ok thanks I may have to do that but right now I have a temp fix in there on Kitchen slide, other side isn't bad yet but imagine over time I will need to do what you did
slide, slide out
