Old 02-16-2015, 09:21 PM   #451
another_newfie's Avatar
The parts for both main cabin slides have arrived at my dealer. Not bad, about a week from the time I got clearance from PT to have my dealer install them and they have them.
I plan on bringing the unit in to them this coming weekend and dropping it off. I'll be leaving town for work for a few weeks so they have lots of time to do the work.
Tiggerdad, in my case I am almost a year out of warranty. PT did not stall or try and dodge me in any way. I presented with the evidence of the wear, they already knew my unit was experiencing it inside the warranty period anyway. Initially I was going to attend the FROG rally and get it dealt with there, but after that plan fell through I approached them again and they agreed to a dealer fix.
2015 F-350 SRW 6.7 PSD
2014 Crusader 295RST
1 Fantastic DW
1 Amazing DD
1 Beagle that will be missed (RIP Zeus)
another_newfie is offline   Reply With Quote
Old 02-17-2015, 05:04 PM   #452
Has anyone ever seen these so called slide repair kits or have pictures? My dealer called and wanted me to come look at what the factory sent . I am going in the morning. They only sent one kit. I still haven't heard from the factory rep as of yet.
Fufys is offline   Reply With Quote
Old 02-17-2015, 06:23 PM   #453
Platokidd's Avatar
Thumbs up Yep
update
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
nights of camping
2017-67 / 16-92 / 15-73 / 14-60 / 13-33
Seasonal
Platokidd is online now   Reply With Quote
Old 02-18-2015, 10:01 AM   #454
Thanks for the pics Platokidd. So they wrap up around the edges and they are held in place with adhesive only?
1 Fantastic DW
1 Amazing DD
Old 02-18-2015, 12:26 PM   #455
I went to my dealer and looked at the "fix" that PT has sent to repair and fix the slide wear problem. First of all they sent only one plastic piece, I guess it only takes one for each slide. That fix ill only address the edge wear. My biggest problem is the tearing of the fabric at the center of the under slide. It is really bad on the driver's side, but there is also evidence of tearing on the other slide also.
Old 02-18-2015, 12:42 PM   #456
Platokidd's Avatar
Good question, Im not sure if the screws on the side of the slide go thru the strip or not. But it is secure and seems to be holding under the trim piece fine.
Now as to the double side tape that holds to the under side to the fabric.
Mine in one spot on the outside end last fall started to lose it hold.
Fortunately, I had some darco tape laying around and applied a small piece of tape to strip to hold it.
One thing I asked my dealer to do that they didn't, was to install the strip so it would stay in contact with the wear bar and slide bottom at all times.
In other words when my slide is extended, the wear strip doesn't make contact with the wear bar. (or its the other way around, cant remember right now)So when I retract the slide it has to glide up on the wear bar, good thing the bar has a radius on the top. Now thats not a problem yet, but you can bet Im watching closely.
Other then that the wear strips are doing a fine job protecting the area it covers. Which is 90% of where the wear is on my unit.
I use 303 aerospace on the strips and the fabric bottom to keep them clean and slick.
I also use slide slickers on the carpet areas of my unit.
Hope all that made sense...
Added another pic , so maybe the screws do go thru the strips
Slide out /Underside wearing
nights of camping
Seasonal
Old 02-18-2015, 06:23 PM   #457
Platokidd's Avatar
Had this wear mark in the center of my slide.
Thought it could be caused by this section of the flooring
But I have a hunch it may have been cause by the heat vent in the floor. Its close to being in line (I think) So I changed / upgraded the vent to one that can be closed and it sits in the hole better.
nights of camping
Seasonal
Old 02-19-2015, 04:30 AM   #458
Witch Doctor's Avatar
Attachment 69885
Attachment 69886
I would go buy my own plastic and install it over that area. I had that same problem and found that the screw head holding down the wear strip was sticking up. I removed the wear strip and counter sunk the holes and moved it over one inch. It ended my problem. I know it wasn't from my register because they are in the center of the unit. Not sure were your registers are located. Seems we been fighting this crap forever, just a poor design and poor fix's by the factory. Mine was the exact same place on my Rockwood.
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Witch Doctor is online now   Reply With Quote
Old 02-20-2015, 07:13 PM   #459
Looks like PT is closed or out of business. Both my dealer and I have been trying to call them and no one is answering the phones. Looks like I may have to fix my camper myself.
10 Chevy Silverado 3500 CrewCab
6.6L Duramax with EFI Live Tuner with 5 levels
560hp 958 Max torque 3:73 gears
2015 Crusader 351REQ
cajun225 is offline   Reply With Quote
Old 02-20-2015, 10:38 PM   #460
Platokidd's Avatar
caller I.D. JK.. Sounds kinda odd, what number are you calling?
574-862-1025
nights of camping
Seasonal
slide, slide out
