Old 02-23-2015, 12:14 PM   #471
Witch Doctor's Avatar
Originally Posted by Platokidd View Post
Thought you said once, yours had a 45 degree on the inside ends. The one's I've seen on Rockwood are more flimsy.
You are 100% correct go's over the edge of the slide floor but really not needed. When the slide picks up on retract it really has nothing to do. When the slide rolls over the wear bar is wear it counts. That still would protect the edge from water and 4" in.
Coachmen M/H
Concord
2018 / 300 DSC
Old 02-23-2015, 12:44 PM   #472
Platokidd's Avatar
Dont think that would work on my laminated bottom slide out. There is no pick up on retract. Its a straight shot in and out, no room for the 45 deg. section.
Thats the side they use the fabric wrap on the entire slide bottom. Now on the opposing wood slide bottom with taped ends it may work, dunno.
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
nights of camping
2017-67 / 16-92 / 15-73 / 14-60 / 13-33
Seasonal
Old 02-23-2015, 02:00 PM   #473
You cut the 45 degree off after all it is plastic. Then you end up with a strip 90 degrees up on the side that screws in under the trim and taped piece of plastic 3" or so on the bottom to the underbody. the more it rolls in the more it seals. But your edge is sealed from water and you have something to cause less friction. This is pretty simple to do, just don't over think it like an engineer design person who did the original.
Coachmen M/H
Concord
2018 / 300 DSC
Old 02-23-2015, 02:02 PM   #474
Brother Les's Avatar
thanks for the thread, unit going to dealer next week to look at.
Brother Les
Old 02-23-2015, 04:13 PM   #475
M109Rrider's Avatar
I made my own slide sliders out of vinyl gutter covers I picked up at Home Depot. I cut flange piece off leaving a flat piece of 1/32" thick vinyl about 6" wide and 4' long. ran 3 strips under my big slide. Works good. Thinking of adding 2 more since the slide is so long.
Jason and Billie
2005 Dodge Ram 2500, 4X4, QC/SB 5.9L Cummins
15k non-sliding Hidden Hitch (they lied, it's not hidden at all)
2011 Prime Time Crusader 320RLT
M109Rrider is offline   Reply With Quote
Old 02-23-2015, 06:27 PM   #476
Platokidd's Avatar
nights of camping
Seasonal
Old 02-23-2015, 08:26 PM   #477
M109Rrider's Avatar
Yea, pretty much..lol. I'll try to get a pic tomorrow.
Jason and Billie
Old 02-24-2015, 06:12 PM   #478
Texas
Here is my Fix for the Slideout Bottom Wear Problem
I purchased a 24"x48" 1/4 sheet of UHMW (white) for about $55 on Ebay. Cut 2 - 6" wide x 48" strips, crosscut to 27" for my 24" deep kitchen slide, rounded over the edges, drilled and counter sunk for screws. Attached w/ #10 x1" flat head screws, also added some caulking on the top side around the edge and around each screw holes before attaching to the slide-out. I did have to jack up the slide to make room for the new runners. I did adjust the slide up 1/4" as well to compensate for the new 1/4" runners, lower rubber wiper is still in contact w/ bottom of the slide and there is still plenty of room up at the roof gasket.
So after a day's work this is what I have.. a 6" wide runner on each end plus my cutoffs were ripped down the middle to make 2 - 3" wide runners, staggered for the required length of 27" in the middle under the frig.
I still have enough material left over from the 2x4 sheet to make runners for the living room slide if I see wear starting to happen..
Hope this help, and I'll keep you posted of how things look going forward.
Note: UHMW was easy to cut and shape w/ regular wood working tools, table saw, router table, etc.
Name:	2x4 Sheet UHMW.jpg
ID:	70184   Click image for larger version
Name:	8th inch round over.jpg
ID:	70185   Click image for larger version
Name:	Cut to 6x27 drilled and counter sunk holes.jpg
ID:	70186   Click image for larger version
Name:	Rear Installed.jpg
ID:	70187   Click image for larger version
Name:	Center Installed.jpg
830hvacman is offline   Reply With Quote
Old 02-25-2015, 02:03 AM   #479
Those look real good, but you need to protect the edge from seeping water with something. by the picture it still looks like material there, am I wrong?.....
Coachmen M/H
Concord
2018 / 300 DSC
Old 03-01-2015, 10:35 AM   #480
Well after 3 months of being at the dealer to fix under slide and other issues we got our 351 REQ back. The under slide issue was repaired with tape. Not happy but that's all I can get out of the dealer and Prime Time. They must be screening calls and emails because they will still not answer emails and call or respond to us. This is my very first camper and Prime Time. We love the floor plan of our camper but do not think we will ever buy another FR/PT unit.
10 Chevy Silverado 3500 CrewCab
6.6L Duramax with EFI Live Tuner with 5 levels
560hp 958 Max torque 3:73 gears
2015 Crusader 351REQ
cajun225 is offline   Reply With Quote
slide, slide out
