Old 03-01-2015, 12:15 PM   #481
Texas
Originally Posted by gljurczyk View Post
Those look real good, but you need to protect the edge from seeping water with something. by the picture it still looks like material there, am I wrong?.....
The black material was still in great shape, some on the bottom and up the sides to the molding, so I left it as it was. The white runners do have sealant on top, around the edges and around the screw holes, then it was positioned and screwed down. Kind of a "gasket" between the two... Also the "squeeze out" was cleaned up around the edges and screw holes... I am hoping this works in the long term, but time will tell.. Really slides a lot easier by what I can tell..
Thanks and Happy Camping!!
830hvacman is offline   Reply With Quote
Old 03-01-2015, 12:24 PM   #482
Platokidd's Avatar
Think you have a crusader 295? isnt that a laminated slide bottom? If so, Im a little concerned about the screws pulling out and becoming a bigger problem.
It was important to me to wrap the sides as there is no other protection there but fabric.
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
nights of camping
2017-67 / 16-92 / 15-73 / 14-60 / 13-33
Seasonal
Old 03-01-2015, 12:28 PM   #483
Platokidd's Avatar
Originally Posted by cajun225 View Post
Well after 3 months of being at the dealer to fix under slide and other issues we got our 351 REQ back. The under slide issue was repaired with tape. Not happy but that's all I can get out of the dealer and Prime Time. They must be screening calls and emails because they will still not answer emails and call or respond to us. This is my very first camper and Prime Time. We love the floor plan of our camper but do not think we will ever buy another FR/PT unit.
What?? prime time has always responded to me , if not the first time maybe on the 2nd or 3rd time.
Are you relying on your dealer to get a hold of them?
nights of camping
Seasonal
Old 03-01-2015, 01:13 PM   #484
Still waiting
I am having the same communication problems with PT. I have called and left my number and have e-mailed over two weeks ago without any returns. PT sent my dealer one plastic panel to repair my slide wear area and they taped the area that was ripping at the center of the driver's side slide. I requested that they contact PT about adding the plastic panel to the other slide since it is also showing wear. My 295 has been in the shop since Jan 15 waiting on PT to approve action on repairs. I am wearing thin on patience, but I am at PT's mercy and my warranty will run out in May, and I was told that the extended warranty probably not cover any future problems . :0(
Fufys is offline   Reply With Quote
Old 03-01-2015, 01:25 PM   #485
Platokidd's Avatar
Save all your documentation , emails and anything else. You reported this while under warranty.
I just cant understand whats going on with all the lack of response from prime time. They have always been so good returning calls and email from me.
nights of camping
Seasonal
Old 03-02-2015, 08:51 AM   #486
zs325RES's Avatar
I purchased a 24"x48" 1/4 sheet of UHMW (white) for about $55 on Ebay. Cut 2 - 6" wide x 48" strips, crosscut to 27" for my 24" deep kitchen slide, rounded over the edges, drilled and counter sunk for screws. Attached w/ #10 x1" flat head screws, also added some caulking on the top side around the edge and around each screw holes before attaching to the slide-out. I did have to jack up the slide to make room for the new runners. I did adjust the slide up 1/4" as well to compensate for the new 1/4" runners, lower rubber wiper is still in contact w/ bottom of the slide and there is still plenty of room up at the roof gasket.
So after a day's work this is what I have.. a 6" wide runner on each end plus my cutoffs were ripped down the middle to make 2 - 3" wide runners, staggered for the required length of 27" in the middle under the frig.
I still have enough material left over from the 2x4 sheet to make runners for the living room slide if I see wear starting to happen..
Hope this help, and I'll keep you posted of how things look going forward.
Note: UHMW was easy to cut and shape w/ regular wood working tools, table saw, router table, etc.
Very similar to what I did with countertop laminate. I did notice that my slides run more smoothly and with less effort for the linear actuators after the mod. I also sprayed the laminate surface with silicone for a very slick surface.
Just an observation - regarding your use of the .25" material, I would be concerned about the rest of the floor on your slide that is now effectively not supported by the plastic runner that the floor slides on, and is supposed to be supported along its length when the slide is deployed. This is the reason I used the thinnest material I could think of.
We are mostly seeing wear at the edges of our slides because this is where the load is highest due to the load bearing walls, so addressing the problem here is a good start.
I should have looked at some of the new models at the RV show in January to see if anything had been done to address this obvious problem.
2013 Crusader 325RES Touring Edition
2006 Silverado 2500HD LT SW ECSB, 6L LQ4/4L80E 4.10s w/16K Curt slider (not necessary), Air Lift bags & Black Bear Performance tune & CAI
Norm & Karen Zondervan
zs325RES is offline   Reply With Quote
Old 03-02-2015, 02:56 PM   #487
Texas
I was thinking the same thing, about some of the un-supported flooring between the runners, and since I have lots and material left over - about going back under w/ a least 2 more 6" wide runners between the existing 3 runners now. But since we really do no walk on this floor area, I will see how it works out during our 1st trip w/ the new (only 3) runners. Thanks!!!
Old 03-04-2015, 11:44 AM   #488
Name:   ImageUploadedByForest River Forums1425490904.965678.jpg
Name:   ImageUploadedByForest River Forums1425490932.079173.jpg
. Pics showing tearing and wearing of under slide material. #1 also shows an apparent patch that was.made before we bought it. This is a Crusader 295.
Old 03-04-2015, 12:58 PM   #489
Witch Doctor's Avatar
Attachment 70676Attachment 70677. Pics showing tearing and wearing of under slide material. #1 also shows an apparent patch that was.made before we bought it. This is a Crusader 295.
If you want to try what Rockwood uses on the edge. I have 4 new That if you pay shipping you can have them and try it. PM me if you want them
It will atleast stop water from seeping in the edge. Just cut the 45 degree off. they are about 41/2' x 23/4" wide and go's up about 2" under the third picture. Or if any others want to try them, first come gets them.
Name:	slide edges strip 001.jpg
ID:	70682   Click image for larger version
Name:	slide edges strip 002.jpg
ID:	70683   Click image for larger version
Name:	slide edges strip 003.jpg
Coachmen M/H
Concord
2018 / 300 DSC
Old 03-04-2015, 01:23 PM   #490
another_newfie's Avatar
I received a call from my dealer, they tried to install the 'slide kit' and in their own words after running the slide in and out the kit 'shattered'. Not sure what they meant by that, but it was clear they felt the solution would not work.
They have reached back out to PT and we will see what happens next.
2015 F-350 SRW 6.7 PSD
2014 Crusader 295RST
1 Fantastic DW
1 Amazing DD
1 Beagle that will be missed (RIP Zeus)
another_newfie is offline   Reply With Quote
slide, slide out
