Old 11-08-2015, 06:55 PM   #581
Send a message via MSN to Tiggerdad
Has anyone seen the Darco wrap failure on a bed room Swintek driven slide? The slide has 2 rollers. The one on the right barely contact the bottom and will turn and sometimes skip with no damage to the Darco and has a slight gap when fully opened. The left roller contacts all the time and does not turn. It touches the bottom all the time and has torn and damaged the bottom.
2013 Crusader 330 MKS
2013 Chevrolet Silverado LT 2500 D/A
Tiggerdad is offline   Reply With Quote
Old 11-10-2015, 07:17 PM   #582
Platokidd's Avatar
The slide out leaking postings would be better off in a thread of its own. Rather then change the topic of an existing thread. Also less confusing to folks looking for info on either topic.
Update: If you were following the slide-out leaking posts , here's a link to the new thread.Slide out leaking
Tiggerdad, I moved the 2nd half of your post to start the new thread topic.
Site team
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
nights of camping
2017-67 / 16-92 / 15-73 / 14-60 / 13-33
Seasonal
Old 05-10-2016, 04:21 PM   #583
Hey guys. Has anyone looked at or tried the Vinyl flashing as an option or replacement fix for the plastic slide strips? I found a roll of vinyl flashing at Home Depot. It is 14" wide and 30' long. The label claims it is bendable and will hold its shape. I was thinking of getting a roll and creating a bend that would slip under the trim on the end of the slide to cover the Darco fabric. I'd cut the Vinyl into 4 inch strips and use 3M double side tape to secure. I don't know if this will work. I figured it would be more durable than the plastic strips. However, I was not sure if anyone else has tried the vinyl option before I give it a whirl.
2914 Tracer 2950BHS
Griswalds is offline   Reply With Quote
Old 05-10-2016, 08:21 PM   #584
So the black wrap tears from usage is their a DYI kit you can install?
esmoglo is offline   Reply With Quote
Old 05-11-2016, 01:35 PM   #585
another_newfie's Avatar
The PT fix is holding up with zero issues on my rig. I would personally think it would not be that hard to come up with something yourself. The pressure of the slide itself will for the most part keep it attached. Just a few screws in the side to hold it there should work.
2015 F-350 SRW 6.7 PSD
2014 Crusader 295RST
1 Fantastic DW
1 Amazing DD
1 Beagle that will be missed (RIP Zeus)
another_newfie is offline   Reply With Quote
Old 05-11-2016, 02:05 PM   #586
The dealer installed the strips delivered by FR.
On one he did not clean the surface properly and that one fell off,
I re-glued in with contact cement, now it is OK, I hope
wamafi43 is offline   Reply With Quote
Old 05-11-2016, 04:23 PM   #587
M109Rrider's Avatar
Kind of what I did. I used vinyl gutter guards.
Jason and Billie
2005 Dodge Ram 2500, 4X4, QC/SB 5.9L Cummins
15k non-sliding Hidden Hitch (they lied, it's not hidden at all)
2011 Prime Time Crusader 320RLT
M109Rrider is offline   Reply With Quote
Old 05-14-2016, 05:33 PM   #588
Here's my attempted fix. Went to Joann Fabrics and purchased two yards of 16 gauge clear vinyl for $12 dollars. Cut the vinyl into strips 1.75 inches wide. Removed the trim molding and inserted the vinyl behind the trim. I used silicone to as a sealant around the screws. Tighten the screws, applied silicone to the top of the trim, and done. The vinyl extends 1/4" below the bottom board. As soon as I was done it started to rain. So far it's working as an effective drip edge. No water on the bottom of the board. Only time will tell how the vinyl will hold up. However, it only took me about an hour to do both rear slides. If it lasts a year, I can redo it. Better that than a rotten floor. Here are a couple pics of the finished job.
Name:	ImageUploadedByForest River Forums1463265210.600413.jpg
Name:	ImageUploadedByForest River Forums1463265223.668721.jpg
2914 Tracer 2950BHS
Old 05-14-2016, 06:58 PM   #589
I used some 90 degree flashing from Home Depot to do the same thing. Watch the silicone carefully. Has a tendency to shrink and pull loose. Dicor or a polyurethane sealant is the best and permanent.
Old 05-14-2016, 09:41 PM   #590
WFD
Hey Griswalds.....doesn't the fact that it extends about 1/4" below the trim piece interfere with the slide moving in and out. I would think that 1/4 " would catch or something on the way in and bend or tear, or get hung up on the hard plastic piece on the floor of the trailer as it comes in.
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
WFD is offline   Reply With Quote
slide, slide out
