01-19-2017, 08:10 PM
#601
Here is our update
The dealer went to bat to get our extended warranty to cover our repair after initially telling us no warranty would cover
However, with our deductible and two trips up to dealer to drop off and pickup , we decided to have a mobile tech come to our house for the same price
Dealer countered back they would take $$ off deductible and pick up unit but we would have to get it when done
Still was cheaper to have mobile tech and they will be installing new awning fabric at same time
Dealer had slide wear strips sent to us from FR at no cost - we will be having mobile service install them on BOTH of our large slides in the spring - only one is showing wear but we are doing both now
We will be having the darco material removed on the worst slide and treating the exposed wood with a line-x type material in addition to the wear strips
Other slide will get just wear strips
Parts are approx $35 per set - you get two pieces to do front and back edge of slide
The slide will be jacked up slightly to insert wear strips
Sent from my iPhone using Forest River Forums 🇺🇸
01-19-2017, 08:13 PM
#602
Originally Posted by Wobbles
Ask the FR rep to give you the numbers for any approved local RV techs or dealers in your area.
Yea North Trail RV here in FL has a 3 1/2 month wait time just to get in, dealer 1 1/2 hrs away from my house have done work for me two times before hope they can squeeze me in (snow bird season here in FL keeps the dealers busy). Problem I have is local Forest River dealers can deny me service because "Prime Time" is not proper Forest River just like we can't purchase the extended two year Forest River warranty kind of moronic really.
01-19-2017, 08:23 PM
#603
Originally Posted by esmoglo
Well this is also happening to our 2016 Prime Time Crusader purchased in May of 2016 sent an email to rkoelndorfer@forestriverinc.com as my unit is till under warranty. I understand the fix is the installation of long plastic type panels seems simple. Would imagine they will want me to take the Crusader into the dealer for me that's the worst part 1 1/2 hrs to drop off 1 1/2 hrs to come home and repeat for pick up such a hassle.
I fix what I can on my own & don't go to the dealer unless I have to. So can someone explain the installation process?
I did it myself. Was pretty easy.
1. Removed the existing trim pieces.
2. Extend slide almost all they way out, but before it sets down into the out position.
3. Slighty jack one end of the slide to install the additional trim piece. I used a floor jack with scrap 6x6's to reach high enough
4. Repeat other end of slide.
5. Replace trim pieces and caulk. I installed them upside down. Seemed to fit better with the additional thickness of the new trim.
I didn't have to do any adjustment of the slide mechanism.
01-19-2017, 08:24 PM
#604
Yea North Trail RV here in FL has a 3 1/2 month wait time just to get in, I have a contact 1 1/2 hrs away from my house they have done work for me two times before hope they can squeeze me in (snow bird season here in FL keeps the dealers busy). Problem I have is local Forest River dealers can deny me service because "Prime Time" is not proper Forest River just like we can't purchase the extended two year Forest River warranty kind of moronic really.
A "Mobile RV" tech is the only alternative I can think of now. Sorry.
Stinks that dealers are getting away with that. I bet that would not hold water with a FR company rep...
Bob & Michelle
2016 Ford F-250 Lariat 4x4
2017 Flagstaff Super Lite 526RLWS
01-19-2017, 08:33 PM
#605
interesting did you have to purchase the pieces on your own or do they provide them under warranty ?
01-19-2017, 08:38 PM
#606
They were sent to us no charge - we will pay the mobile tech for install
01-19-2017, 10:20 PM
#607
Might be a good idea to inform the tech about the fridge slide construction.
See #3 in this post from the rvguy. Laminated Floorbrace
http://www.forestriverforums.com/for...tml#post457231
From that post:
Most of our Kitchen slides in all brands are made in-house using laminated construction due to the increased weight loads. With a laminated floor, the bottom exterior layer is a product called FloorBrace. FloorBrace is comprised of multiple layers of cross-weaved polyester fibers designed to breath yet provide moisture protection. Adding the laminated layer of FloorBrace increases the strength of the floor as well. The inner layers of FloorBrace are white.
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
Seasonal
Zelda the campin dog
01-19-2017, 10:35 PM
#608
From that post:
The layer next to the darco wrap is plain cheap OSB - we can see it very definitely in the worst area of gouging
I will inform the tech though
01-19-2017, 11:37 PM
#609
Berkshire 390QS
Many Berkshires have had this problem, they sent me 5 plates, 8" wide, 22" long made of 1/8 alum with holes that I mounted on bottom of slide. Not hard to do, just took some time. They provided the plates free of charge.
2015: 188 days, 2016: 72 days, 2017: 185 days: 2018 182 days
2019: 156 days (2009 Berkshire, 390QS, and toad)
01-23-2017, 05:06 PM
#610
Mr. (My name)
Rick is no longer with the company. We are sorry that you are experiencing issues with your unit and as per the warranty guidelines you may reach out to your closest forest river dealer to schedule warranty repair of the unit. The closest dealer to your provided location is Planet RV in Davie,FL and their telephone # is 954-514-7860. Should you need further assistance or advice please feel free to contact me directly using the information provided below.
Thank you,
Larry Elswick
Retail advisor
Prime Time Mfg
lelswick@forestriverinc.com
574-862-3092
Guess Rick is gone this is the response I received today. Called Larry he did not know a thing about this. Bring it to the dealer have them file a warranty claim is what I was told. Larry did not even know the part numbers or has ever heard of this issue.
Local dealer ONE; yea we can get to you in 3 ½ to 4 months by then my warranty will be over how convenient for them.
Local dealer number two,
Dealer: did you purchase from us?
Me; No,
Dealer: what brand?
Me: Prime Time
Dealer: we don’t service that brand.
Me: It’s a Forest River product why not?
Dealer: Because we reserve the right to not service brands we do not sell even if it’s under the Forest River umbrella.
Me: pissed off said noting but “thank you”.
Love it! NOT.. anyone know what the part numbers are? Are the panels universal? This is happening on my large side (only have two).
01-23-2017, 06:56 PM
#611
Mr. (My name)
Thank you,
Larry Elswick
Retail advisor
Prime Time Mfg
574-862-3092
Me; No,
Dealer: what brand?
Me: Prime Time
Too bad Rick was very helpful. You could ask for Shane Imus or Rodger. They both are very much aware of this problem. The prime time part numbers are in the first post of this thread. Make sure pt marks it in your file so you have record of reporting it.
What model do you have?
Seasonal
01-23-2017, 08:19 PM
#612
Roger is no longer with PT either....
My contact was Neil Wilson
The part numbers they sent me are
10F17448A - left hand facing
And
10F17449A - right hand facing
Slide out repair kit is what its listed on packing slip
Ours were sent directly to us from Prime Time plant in Indiana
01-23-2017, 10:02 PM
#613
And
We both have similar 2014's. My strips had no left or right side.
Seasonal
01-25-2017, 07:48 AM
#614
And
Will call PT today hopefully Neil Wilson or Shane Imus are still at PT since they know about the issue.
Part numbers provided were for your large slide?
01-25-2017, 07:55 AM
#615
Thats what they sent - we have a 325RES with the kitchen/sofa slide and a large deeper slide on door side with table and recliners
Kitchen slide is not as deep
We are doing both large slides - they sent two sets - probably have to trim one set
01-27-2017, 04:02 PM
#616
You're installing them yourself? Did they come with instructions?
01-27-2017, 04:35 PM
#617
We are having a mobile tech install - they are also putting on new awning fabric same trip
We could do all work ourselves but going to hire this job out - worth the money to let someone else on the ladders and on the ground 😊
Tech has done this work before so we will figure it out - four pieces of plastic should not be that hard
01-27-2017, 07:18 PM
#618
If you have the wear strips could you post pics of them? You posted differant part # then I received and would like to see the difference.
Seasonal
01-27-2017, 07:38 PM
#619
I gave them the part number I found on here and they said it changed to what they sent me
Here are the pics of the strips:
Attachment 128768Attachment 128769
01-27-2017, 07:39 PM
#620
