Old 11-27-2012, 02:33 PM   #21
Its back at the factory.
Just called the dealer and my Tracer was picked up 11/21 to go to factory for repairs. Slide was the original problem but after the dealer installed some bigger rubber blocks I got 4 seams humped up pretty bad over the top of the slide, I and the dealer think it is delamination. Not saying the rubber blocks caused this but that is when it started. I am really hoping for a good outcome on this, we really like our Tracer. I guess we were just one of the unlucky ones who has some problems. Hope it gets fixed soon.
Just thought I would update my post.
wvbike_99 is offline   Reply With Quote
Old 10-20-2014, 04:40 AM   #22
JoeyO's Avatar
Send a message via Yahoo to JoeyO
WV,
What was the final outcome for the fix? My 3150 BHD is now doing the same, struggles when bringing it in, then pops, the comes in. But recently, it's been stalling just before it lifts out of that "pocket". We bought a new battery, and that helped bring it in, but curious what was done by Norco and PT. We have a 2012 Tracer 3150 BHD Executive Series, and really enjoy it. Hope you read this and update the results to your fix.
Thanks, Joe
OTeam
2018 Genesis G80
2010 370z Convertible 6 Stick
2011 Expedition 5.4L 4x4 Limited
2018 Highland Ridge 275 Light
Semper Fi
JoeyO is offline   Reply With Quote
Old 10-20-2014, 05:52 PM   #23
Platokidd's Avatar
Originally Posted by JoeyO View Post
WV,
Thanks, Joe
Have you treated your wiper and seals?
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
Seasonal
R.I.P. Luke the campin dog
Old 10-20-2014, 06:31 PM   #24
JoeyO's Avatar
Not certain what the wipers are or where they are located. Please let me know.
The black seals that go around the perimeter of the slide outs are in great shape though. I think part of my problem was that the terminals were not properly tightened at the battery. =-/ I didn't notice that till the other day....
OTeam
2018 Genesis G80
Semper Fi
Old 10-20-2014, 06:48 PM   #25
Platokidd's Avatar
Sounds like the black seals are all good lubed. Sometimes if not treated they can cause excessive drag and jerky slide operation. I use 303 aerospace on them. Baby powder works too.
The tracer is also cable driven on the slide-outs and need adjusting at times.
My old tracer (2013 2670bhs) had the tips of screws from the dinette going thru the bottom of the slide out. The screws would catch on the wear bar causing the slide to jerk and POP. Ever notice little black fragments on the floor? On mine that was pieces of my wear bar being torn up by the screw tips.
Have you tried your slide since you tighten your battery cable?
Seasonal
Old 10-21-2014, 10:19 AM   #26
Not fixed
WV,
Thanks, Joe
Mine went back to factory 2 separate times, both times slide was worked on. First time they told me they installed a new roller. Seemed to stop the loud pop when u first started bring in slide. However the cables were dropping on one side when it came back. When it was at factory the second time they were supposed to address the loose cables but when I got it back they were no better than before. Now it pops and strains and jumps up and down something terrible when I bring in slide. Last time I thought it was not going to come up and start in but finally lunged and worked. Every time we go camping I WORRY WILL THAT SLIDE COME IN!!! Seen some new Tracers on lot and I think they have stopped using that cable slide system. Wish I had bought the Rockwood instead of the Tracer. Hope u get your problems worked out.
led pad
