Old 06-08-2012, 08:44 AM   #1
next2dixie's Avatar
Slide Question on 301RLS
This is the first TT I've owned with a large slide. Is the alignment of the slide flange to trailer side wall proper? When the slide is extended the inside flange is parallel to the inside wall but the slide floor has a slight port list. When the slide is retracted the upper flange contacts the trailer and the room will lift until it's sealed on the top and sides. Thanks for your help
next2dixie is offline   Reply With Quote
Old 06-08-2012, 09:53 AM   #2
I don't have that TT, but that sure doesn't look right to me. Do you push the retract switch until you hear a ratcheting sound (if electric)? Has it been like that since you bought it?
Len & Cheri is offline   Reply With Quote
Old 06-08-2012, 02:09 PM   #3
next2dixie's Avatar
The picture is before the slide was totally retracted. It will retract until flush with the side of the trailer. We bought the trailer new about 5 weeks ago and was like this when we did the orientation on the dealers lot... but I was inside the unit when the slide was closed.
Old 06-08-2012, 08:16 PM   #4
rracer5's Avatar
Normal
"PT Crew Members Since 9/2010"[/I][/B]
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
Old 06-09-2012, 07:36 AM   #5
next2dixie's Avatar
Originally Posted by rracer5 View Post
Normal
Thanks rracer5
Old 06-10-2012, 08:12 AM   #6
6.4 tow rig's Avatar
Yep, completely normal
2013 Primetime Lacrosse 318BHS
2008 F-250 Powerstroke
6.4 tow rig is offline   Reply With Quote
