Old 02-29-2012, 11:50 AM   #1
slideout maintenance
2 Questions for those of you that complete your own maintenance....
1. What do you use for lubricating your slideout mechanisms and where do you apply the lubrication?
2. What do you apply to the seals to improve longevity?
2011 Lacrosse 318BHS Touring Edition
2012 Ford F150 SupCrew 4x4 XLT 6.5' Max Tow
padave65 is offline   Reply With Quote
Old 02-29-2012, 11:56 AM   #2
1) I use a dry lube. Any of the commercially available ones will work just fine. You can get spray cans of the stuff at any auto parts store. With the slide fully extended, I crawl under the slide and spray everything I can see and reach.
2) I use ProtectAll on my slide seals. In fact I use it on all rubber gaskets for car.truck, and RV. Seems to work well and the seals are still soft and pliable.
Old 02-29-2012, 03:01 PM   #3
frankm's Avatar
See below. I have had good results with ProtectAll products, so why not use these too. I have included the CW links for reference, but you can find these products in other places.
http://www.campingworld.com/shopping/item/protect-all-slide-out-dry-lube-protectant/17390
http://www.campingworld.com/shopping/item/protect-all-slide-out-rubber-seal-treatment/18633
Frank & Rita M
2016 Ford F-150 XLT Ecoboost
2017 Rockwood 2703WS
frankm is offline   Reply With Quote
