Old 10-08-2018, 07:12 PM   #1
Slow slides
On the Crusader 355BHQ we have 4 slides, all electric. 3 have the in-wall Lippert with gear track below the slides. The 2 in the back, opposing bunk room are painfully slow. Lippert's troubleshooting included among other things, low voltage and bad ground. Volts are good so I'm going to look for the ground connections. The other in-wall slide in the living room is much bigger and moves pretty good. Bedroom slide has different mechanism, gear drive on the side wall. What ground should I be looking for? I'm leaning towards a ground for the 2 rear slides since they are the slow ones but not sure where a common one is. I could remove sections of the Coro-plast to get to the motors, precut access panels, but not sure if there is another wiring location I should find.
2007 Itasca Horizon
2012 Jeep Wrangler Sahara
2015 Harley Davidson FLHTK
2012 Prime Time Crusader 355BHQ
2017 Ram 3500 CC 4WD LB
chunker21 is offline   Reply With Quote
slide
