Old 02-27-2012, 08:28 PM   #1
jtad's Avatar
sound bar removal
Anyone know what holds the RCA sound bar in? How do I get that thing out of there?
2011 Cursader 298 BHD
2012 F-250 FX4 6.7 Power Stroke
B&W Companion Hitch
Days Reserved for 2012: 39
jtad is offline   Reply With Quote
Old 02-27-2012, 08:30 PM   #2
M109Rrider's Avatar
On mine you remove the front of the cabinet then it screws in from the bottom
Jason and Billie
2005 Dodge Ram 2500, 4X4, QC/SB 5.9L Cummins
15k non-sliding Hidden Hitch (they lied, it's not hidden at all)
2011 Prime Time Crusader 320RLT
M109Rrider is offline   Reply With Quote
Old 02-27-2012, 09:42 PM   #3
Crusader's Avatar
Rrider is right....There are two screws on each side of the cabinet. Remove screws and pull the cabinet forward. You will then see two screws that go into the bottom of the sound bar. Its not a vary good way to mount the sound bar. I put two dabs of hot glue on the top of the sound bar to act like a shim, to hold it down. It was bouncing loose off the screws. Now it stays in place.
Crusader is offline   Reply With Quote
Old 03-12-2012, 11:04 AM   #4
LKicklight's Avatar
Sound Bar
Mine has been out so many times, that now the dealership has put snaps in place of the screws....Crusader 270 RET....
Anyone still having a problem with the sound bar coming on all by itself?
Mine stopped for awhile, but now its back...try un-plugging the unit for a day..seems to stop it for awhile..
LKicklight
LKicklight is offline   Reply With Quote
