Old 09-06-2013, 08:30 AM   #1
Stains on front cap - 290RLT
I have some brownish stains - almost like drops on the top side of the front cap of my 290RLT. I've tried black streak remover, goof off and simple green with zero success. Any recommendations on how to clean stains from the front cap would be greatly appreciated. I believe it is made from some kind of plastic rather than fiberglass like the rest of the camper? I also posted this in the maintenance section, but got only 1 response...
Dennis & April Holder
2012 Prime Time Crusader 290RLT
DHolder is offline   Reply With Quote
Old 09-06-2013, 03:56 PM   #2
irishrv's Avatar
I've had good luck with turtle wax bug and tar remover.
2014 295rst TE Champagne
09 GMC 2500HD D/A
irishrv is offline   Reply With Quote
Old 09-06-2013, 04:13 PM   #3
Rugged Brown's Avatar
I use Nufinish as a good stain remover even though it is intended as a paint protector, like wax.
Terry/Bernadette
Lily the Yorkie
2019 Dodge Ram Sport 1500
2019 FR Vibe 28RL
Rugged Brown is offline   Reply With Quote
Old 09-06-2013, 04:39 PM   #4
5erDriver's Avatar
Hi
Dholder, are they a very small perfect circle about 1/16" , dark brown and an absolute pain to remove??
If yes then you have what's known as artillery fungus or shotgun fungus. Bet youhave a cedar or pine mulch bed close to your camper. It's like a spore that the mulch shoots toward the light, or in your case a bright white surface that reflects it. I had a nightmare with my last camper. Hundred of them. I also found that if you picked off the hard top and then used NuFinish scratch removal cream from the auto store you can get them off but it takes time. My last camper was an aluminum side TT. I now have a fiberglass gel coated 5th wheel which I have waxed. They come off much easier if you can get a good coat of wax on there. Also, get rid of the mulch. Go to recycled rubber.
Hope this helps. If that's indeed what you have but sounds like it. Good luck!!!
2013 Sandpiper 365SAQ
2008 Ford F350 Super Duty
6.4L Powerstroke Long Bed CC
5erDriver is offline   Reply With Quote
Old 09-06-2013, 05:12 PM   #5
VinceU's Avatar
Was it protected with Diamond Shield? I've noted lately, some front ends have an Algea growth under the "shield", which must be removed (3-5 mil film). Not an easy task.
Old 09-07-2013, 02:43 PM   #6
Crusader's Avatar
Clay bar works great !!
Mothers® California Gold® Clay Bar System
TV= 2012 F-150 FX4 Supercab
FW= 2011 270ret Crusader
Hitch= Reese Pro Series 16K Hitch
Crusader is offline   Reply With Quote
290rlt
