Old 07-11-2013, 01:08 PM   #11
Originally Posted by garbonz View Post
...I agree that the only real solution is to get the weight off the wheels, which is a pain to do without alot of buckage..
Less than $80 and a little work and they are permanently stowed on trailer.
2-1/4 Ton Trailer Stabilizer Jack
Name:	Driver Side Axle Jack Retracted.jpg
ID:	35089   Click image for larger version
Name:	Passenger Side Axle Jack Mount.jpg
Old 07-11-2013, 01:20 PM   #12
TURBS's Avatar
Do you have 2 or 4 ?
In front in the middle or behind axles?
Old 07-11-2013, 01:26 PM   #13
2, in front of the axles. Can't get them between due to using the Bal X Chocks.
Old 07-11-2013, 01:28 PM   #14
TURBS's Avatar
I see.
Old 07-11-2013, 01:41 PM   #15
Denver, CO
garbonz's Avatar
Yeah, everything is easy for the COOT, and this IS a great idea, but most of us it would be 80$ and alot of work. Worth thinking about tho. These things will REALLY support 2000 lbs each? WOW.
2017 Fuse 23T
Old 07-11-2013, 01:43 PM   #16
I had my buddy last night who is 275 push on the front corner of the trailer,it moved like crazy. Did up the bars he tried again there was no movement. Maybe if I get in and try it from the inside it might be worse. I also have the front jacks in the 9th hole always try to keep it low
vacationer is offline   Reply With Quote
Old 07-11-2013, 02:09 PM   #17
Not any easier for me than anyone else, just happen to have the equipment to do it. The jacks are SUPPOSEDLY capable of 4500#, but I wouldn't want to trust them for anywhere near that.
Old 07-11-2013, 02:35 PM   #18
Denver, CO
garbonz's Avatar
The equipment is EVERYTHING. and you got it happening...
2017 Fuse 23T
Old 07-11-2013, 02:45 PM   #19
Yes, from the outside mine feels solid as well.
But as you say, inside is a different story. Good, but certainly not perfect.
I think a lot of the movement might also be bouncing on the suspension, as the mickey-mouse frame flexes up and down, so I might have to add midship jacks like OC.
$80 and a half-hour of fabricating, easy-squeasy. .
bakken is offline   Reply With Quote
Old 07-11-2013, 02:58 PM   #20
Originally Posted by bakken View Post
...$80 and a half-hour of fabricating...
More like 2 -3 hours to fab the straps that bolt around the 2 x 4 tube, re-work the top of the jacks and position/mark them so they do not interfere with the tires, remove for welding, painting and re-installation. But, regardless, it is a time saving mod to just take the cordless drill and run them down and then tighten with a ratchet to actually lift the trailer a little off the tires. Sure takes the bounce out of the trailer when used in conjunction with the other things.
