Old 02-24-2015, 08:48 PM   #11
DodgeCamper's Avatar
Any problems with the hard wire models when on generator power?
2015 RAM 2500 Diesel
2015 Lacrosse 329BHT
DodgeCamper is offline   Reply With Quote
Old 02-24-2015, 08:53 PM   #12
Progressive=Lifetime Warranty
SilverbackMel is offline   Reply With Quote
Old 02-24-2015, 08:53 PM   #13
TURBS's Avatar
Run mine on gennie several times a year.
It's possible tho that you'll have to make and use a neutral bonded plug to make it work.
http://www.noshockzone.org/generator...utral-bonding/
TURBS
Old 02-24-2015, 09:19 PM   #14
TURBS
It seems like that is only for motor homes that have onboard generators, am I correct? I have a Lacrosse 329bht, I am thinking of putting a 50amp surge guard or progressive hardware unit. I would just be running on generator occasionally and would get a generator that could carry the full load of 50 amps (my wife doesn't like to hot). Would I still need the plug or does it depend on the generator?
Old 02-24-2015, 09:29 PM   #15
TURBS's Avatar
False.
Any portable gennie may need this plug.
A 50 amp capable generator will neither be light nor quiet.
Old 02-24-2015, 09:34 PM   #16
False.
Thanks Turbs, that is exactly what I was looking for.
Old 02-24-2015, 09:43 PM   #17
mud yapster's Avatar
X3 on the 50 amp hard wire surge.
2014 Palomino Columbus 3650TH
435AH 12V VMax Charge Tanks, 520 watt Monocrystilline Solar Array, Morningstar MPPT TS-60 CC,Morningstar Remote,Cotek True Sine Wave Inverter,Cotek Remote Controller,50amp Progressive Hardwire Surge Protector
2015 Dodge 3500 6.7L 4X4
2011 CanAm Commander XT 1000
mud yapster is offline   Reply With Quote
Old 02-26-2015, 11:09 AM   #18
On my PI with the internal display, there is a button on the display I have to push to let it work with the generators. I think it isn't seeing the ground and won't run in that mode without overriding it (which is normal for the generators). I use two honda 2000s.
2014 Crusader 296BHS
2015 GMC 2500HD Denali
kohai is offline   Reply With Quote
Old 02-26-2015, 11:11 AM   #19
TURBS's Avatar
You need to make a neutral bonded plug to stick in one of the 15 amp receptacles.
I also posted this in post 13
Then you can use your gennie with the PI unit
Old 02-26-2015, 11:34 AM   #20
BigTJohn's Avatar
I do have question for those with the remote readout. Do you actually use/look at the readout or only when first connecting to power? I know when there is an elec problem, the unit shuts down power to the rig, monitors for when it comes back, checks for quality of power then allows power to flow. I guess my real question is: why have a remote readout? Unless you are watching it the moment power goes "wonkie" (an electrical technical term) you will not know why until the power comes back on and you can poll the remote to what the problem "was" - was...the problem is over, nothing you can do about it (if it was incoming power problem) and now the power is back on, your protector has done its job and all is "hunky dory" (the last technical term I'll use). I just can't see spending $100 or so for remote that essentially tells me nothing until after the event. Just sayin'.
Brenda and John
Master Blaster of the Navy
BigTJohn is offline   Reply With Quote
