Old 11-28-2011, 10:06 PM   #1
Surge Protectors...
Sinple Questions...yes or no..Portable or hard wired. What kind?? I hear lots of info, i never used one in my fifth wheel, dosent mean that I shouldnt have, and camping world has them all on sale right now.
kozzy is offline   Reply With Quote
Old 11-29-2011, 12:30 AM   #2
Terier's Avatar
There's good reason for either kind but I opted for a portable unit mostly due to cost. At frist I was afraid about theft but now I just use a lock at the box for peace of mind.
If my unit get stolen then I might pay the extra cost of having one hard wired but for now I rather not have someone playing around with my trailer's wiring. Maybe I would feel differently if my budget wasn't on a diet.
Formerly owned 2011 Salem Cruise Lite 20RBXL & 2011 Toyota Tundra Dbl Cab
Old 11-29-2011, 09:45 AM   #3
frankm's Avatar
Portable, Progressive Industries EMS-PT30C (EMS-PT30C).
Frank & Rita M
2016 Ford F-150 XLT Ecoboost
2017 Rockwood 2703WS
frankm is offline   Reply With Quote
Old 11-29-2011, 11:04 AM   #4
lindy's Avatar
YES on surge protecter. We use a portable one, and I make a metal tab that's screwd to the bottom ot the protector. Then I use a cable bike lock to lock it to the post. When you figure out the cost to replacein every elect component in the trl vs a surge protector the surge protector is a lot less cost, to say nothing of the time lost getting the trl repaired for a voltage surge. Just buy a good one that also has a low voltage shut off capability too. Low voltage can hurt as much as voltage spike
2012 Winnebago "Journey To Insanity" 40U
2008 Dakota Sport 4x4
2004 Subaru Baja - DW's
2006 Honda Shadow Aero - TOAD for now.
F.R.O.G. member
lindy is offline   Reply With Quote
Old 11-29-2011, 11:16 AM   #5
Dave_Monica's Avatar
Your decision may be determined by the ease of access to the power supply wiring to be able to install a 'hard-wired' surge protector.
I installed a HW30 C on our camper as it was easy to access the power supply into the camper behind a removable panel in the bottom pantry cabinet. It can also be easily removed should I sell the camper.
The price between the between the portable and hard-wired versions aren't that different.
Dave
Old 11-29-2011, 12:49 PM   #6
extremebike's Avatar
HI!
Yes for sure use a surge protector. If you are using 30 amp models the cost is not as high as the 50 amp models. I install it at the camper end of the cord and not at the post as they suggest. It makes no difference to suppressing the surges. I hid mine under the spare tire which also kept it dry.
Since I have moved to a 5th wheel I had the dealer install the 50 amp unit in the vehicle as the cost was almost double the 30 amp unit and it was a real chunk to hide. The downside of this is that I cannot see the unit and if something goes wrong then it's back to the dealer. I hope this helps. BTW I had my 30 amp Surge suppressor over 5 years.
regards,
Extremebike
2004 Ford F550 6l Lariat SuperCrew, Fontaine Bed,
Link Systems Air Ride
2011 Sterling 32RL with Michelin XPS tires
extremebike is offline   Reply With Quote
Old 11-29-2011, 04:29 PM   #7
Terier's Avatar
Dave
True but in my case I had to include the cost factor of having it installed. While many members here are able to install it easily this is not the case with me.
Old 11-29-2011, 09:54 PM   #8
Thanks for the input, now I just have to decide on hard wired or portable. Im pretty cionfident I can install it ok, but I want to make sure I can access it easily if I have to..
