Old 09-22-2014, 07:18 PM   #11
ttg;
It $19.27 on Amazon. If you know where you are going to be I imagine they would ship it anywhere you wanted. After all I hear about costs shipping to our cousins up north Amazon could be a good deal. Pay extra if you want it sooner. I am taking it for granted you are in the good ole US of A.
Best of luck
2013 Ford F-350 SD Diesel, 4X4, Crew Cab, Lariat
Sabre 2014 32RCTS, Pullrite Superglide 2900 18K
Davidceder is offline   Reply With Quote
Old 09-22-2014, 09:26 PM   #12
rracer5's Avatar
I have heard of the 3rd handle somewhere along the frame near the tire. Sounds like you can't find it because it fell off during delivery from the manufacturer to the dealer. This has happened to others on this forum and they have remedied that in one fashion or another. And since your dealer didn't see it, they apparently assumed one gray handle dumps both tanks (this is only true on PT's TT's). If you look along the frame for a slot or hole, then pull down the underbelly cover in that area, you'll probably find the elusive valve.........Good luck.
"PT Crew Members Since 9/2010"[/I][/B]
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
Old 09-23-2014, 01:25 PM   #13
I would look for the valve, I expect you will find at least the valve body inline.
A last chance valve like the volterra is great and a must for me as I use a transfer tank a lot at my normal camping location. Its nice to be able to cut off the flow when you need it the most.
jbrostek is offline   Reply With Quote
Old 09-23-2014, 04:04 PM   #14
ttg
ttg's Avatar
Thanks everyone. Roger at Prime Time (Forest River) has guided me to the hole that the missing dump valve shaft should exit from. Today I picked up a "Twist on waste valve". That will keep us out of trouble till the unit goes for repair.
ttg is offline   Reply With Quote
Old 09-23-2014, 04:18 PM   #15
rracer5's Avatar
2014 Sanibel 3250
tank, valve
