Old 11-14-2012, 05:20 PM   #1
Question Tank Heater Switches Identification
Greetings all. My first post here. We picked up our Sanibel 3500 in October and we're pretty happy so far.
I guess I have two questions:
In the control panel box, there are two switches labelled "Tank Heater".
I have four tanks. I'm guessing that one of the switches is for the fresh water tank (which would often be unused) and the other one is for the 3 "holding tanks". Please tell me which of these two switches does what.
Second question: What document am I missing that gives this information? It's certainly not in anything I was given or that I've found on-line.
Thanks!
Barry
Old 11-15-2012, 08:37 AM   #2
wmcclay's Avatar
switches
You can contact Prime Time Customer Service @ 574-862-3001, I have contacted them before and they are very helpfull. Please post the info you receive for others.
Wayne, Donna and Moab
2016 Ford S/D Platinum
2013 Sanibel 3500
Honda 3000 si
4 6 volt batterys
wmcclay is offline   Reply With Quote
Old 11-15-2012, 10:32 AM   #3
Commercial Member
Good question - one of the switches contols 2 waste tanks and one controls the 3rd waste tank AND your fresh tank. We can't get 3 tanks on one switch because it overloads the circuit. With your converter you have limitations on the quantity of available circuits to utilize so we had to group them together. Hope this helps.
PTM
RV Guy is offline   Reply With Quote
Old 11-15-2012, 11:12 AM   #4
Thumbs up
Thanks RV Guy!
So it sounds like I would just want them both on or both off. The way they're wired doesn't give me the option of not heating the fresh water tank, even when it's empty. Can you verify for me then that it's OK to heat an empty tank? TIA....
Barry
Old 11-15-2012, 02:28 PM   #5
Originally Posted by BarryD0706 View Post
Thanks RV Guy!
Don't think you have to worry about it damaging an empty tank as they don't get that hot. If you're worried, put 5 gal of water in it. The thermo-switch in most heater circuits turn on at approximately 40F(+/-5F) and turn off at approximately 60F (+/-5). This allows the tank blanket to add warmth to the tank as the temperature drops.
Old 11-15-2012, 02:57 PM   #6
Commercial Member
We learn something new everyday . . . after talking with BOTH the supplier of the holding tanks and the supplier of the tank heaters, we can say that there would be no problem with having your heaters turned on with your tank empty. As stated above by dunnnc, they are on a thermostat and would turn off way before they could cause any damage to your tank. Hope this helps.
PTM
Old 11-16-2012, 03:40 PM   #7
Thanks all! Glad to hear the system is pretty much fool-proof (which is really difficult to do because fools are so clever).
Barry
Old 12-10-2013, 08:28 AM   #8
itch'n to road trip
campnqueen's Avatar
Send a message via AIM to campnqueen Send a message via MSN to campnqueen Send a message via Yahoo to campnqueen
Well so glad to see this thread. We too have a new RV with heated tanks.
When I asked the dealer and they told me when turned on they are always on. I said there had to be a minimun low temp before they come on and maximum high temp they go off. They said "Nope.. when they are on they are always on and heating." I didnt think this was correct. My dealer leave a lots to be desired. (P.S. never had heated tank before so all the info I can find is very helpful.)
2012 Ford F-250 King Ranch Super Crew Cab 4x4 "Mae West"
2014 Work & Play 25ULA "Ula"
Paula Drake, Ken Cooksey, Sunny Delight & Valor
Jasper Ga.
campnqueen is offline   Reply With Quote
Old 12-10-2013, 11:37 AM   #9
Ok have question or issue with my unit. I have a 2012 Sanibel 3400 which has 4 tanks but I only have one tank heater switch. should I be concerned with tripping the fuse or is mine wired with a double pole switch would allow circuits on one switch
red smoke is offline   Reply With Quote
Old 12-10-2013, 11:53 AM   #10
itch'n to road trip
campnqueen's Avatar
oh yeah.. P.S. my NEW rig came with NO info on the heated tanks.. that were a special order option I paid for. So sad not to know who makes them, how they work or how to use them. FR needs to get a little better at getting this info out to the consumers.
I have always had a lower end, no frills RV unit.. so to get one with a electirc/gas water heater, heated tanks etc is a BIG step up for hubby and me.
Jasper Ga.
sanibel, tank heater switch
