Old 02-11-2019, 08:24 PM   #1
Cdmcq's Avatar
Question Tank vents
Have been experiencing some black tank odour.
Did usual cleaning etc. Went up on roof and put garden hose down the vent with full stream.. no blockage. I was surprised to see only one vent. That means the two grey tanks and black tank are all vented by one vent that is
1 1/2 inch pipe. Never had one vent always have had at least two.
Does your Crusader have one or more vents?
2017 Crusader 31 RST
Cdmcq is offline   Reply With Quote
Old 02-11-2019, 08:42 PM   #2
brookstone345sa's Avatar
Sometimes odors can also come from gray tanks. I had that happen and used some gray tank deodorizer and it solved problem.
Also check air admittance valve, lots of times it's located under bathroom sink or kitchen sink
brookstone345sa is offline   Reply With Quote
Old 02-11-2019, 08:51 PM   #3
heavynlori's Avatar
Our 2014 Crusader 325RES has only one vent on roof
There are two air admittance valves - one under kitchen sink and one under bath sink
Be sure to run water after dumping black and grey tanks to keep water in the P traps
Also make sure you have a cover on your washer drain if you are not using it
Our grey rarely smells and black gets ripe in summer depending on temperature - we are seasonal and dump grey every weekend and black usually every two weeks
heavynlori is offline   Reply With Quote
tank, vent
