Old 07-20-2014, 07:24 AM   #21
My 1240x booster is in the garage.
Dwighop is offline   Reply With Quote
Old 07-20-2014, 07:35 AM   #22
Dwighop,
Where in the garage is yours at? I looked on, in and around the tv cabinet for one.
Macky is offline   Reply With Quote
Old 07-20-2014, 07:48 AM   #23
Not in front of me at the moment but if memory is correct behind the TV up top.
Old 07-20-2014, 08:21 AM   #24
Found it! It was hidden behind the strap that keeps the tv in place while traveling. Believe it or not, this was one of the first places I looked originally but with the strap hanging there, it was covered up and with everything black back there, it was hard to see. Thanks for your help!
Old 07-20-2014, 09:19 AM   #25
Todouble's Avatar
I have painters tape over my blue lights. Let's me still use the button to turn on/off but dulls the blue light in ur face while sleeping.
Todouble is offline   Reply With Quote
Old 07-20-2014, 12:28 PM   #26
Wonder if they changed. I don't find mine that bright.
Old 07-20-2014, 05:33 PM   #27
I hope you enjoy it as much as I do. Let me know how the warranty work goes as I have a couple things I am taking it in for in September.
Went out again this weekend and had a great time. It is the best small (LOL) toy hauler out there
One_Mad_Marine is offline   Reply With Quote
Old 07-20-2014, 09:27 PM   #28
TnT
TnT's Avatar
Picked mine up Saturday went out to the CG. 1st thing that went wrong was the auto level dropped the left side all the way down and raised the right side all the way thought it was going to tip over. So called General got a tech on the phone after 1/2hr. got it fixed it works great makes it so much nicer park than having to get the blocks out. Then the 2nd thing was Sunday morning the shower wouldn't drain looked into it they used so much glue to put the pipes together it drained into the waterless trap and glued it closed and had a small water leak in the drain. Couple small problems but still a very nice trailer I'd give it 9 out 10 and the thing is the wife loves it. Those blue lights I will find a way to disconnect them at least the ones over the bed.
TnT is offline   Reply With Quote
Old 07-21-2014, 05:21 PM   #29
Wish my dw would have settled for the 1032. No half bath pushed us on up in size. Oh well. That's really weird with the blue lights. I'm not sure I would have noticed if I hadn't seen it mentioned on here.
Old 07-21-2014, 06:21 PM   #30
We lost all power to our GFCI outlets when my DW plugged her blow dryer in to the bathroom outlet. It will not reset now so it looks like I will have to replace the GFCI in the bathroom. I have tried all the normal procedures for this type of problem but nothing works so far. The 6 downstream GFCI outlets are also dead but all none GFCI outlets are working.
