Old 03-30-2015, 08:36 PM   #61
Originally Posted by Stormrider151 View Post
Was the AC unit in the bedroom added after the original production of the unit? That would explain why it is trying to cool the bedroom. During the original build of the trailer ducting was run throughout the trailer. If I remember correctly the second unit in the bedroom is not ducted. A solution would be to disconnect and block the venting to the bedroom from the living room AC. This will divert the wasted cooling to the living area and the garage.
Yes both units are stock and ducted. The 1240x comes that way. I don't remember being hot last July at Disney so maybe I just need to get the 2nd unit checked out. Nothing says it couldn't have gone bad like the first.
I think they duct together so you could get by with one unit if you were stuck with 30 amps.
Dwighop is offline   Reply With Quote
Old 03-31-2015, 10:12 AM   #62
Originally Posted by Dwighop View Post
Insulation? I didn't see a lick under the garage. I'm thinking about dropping the fuel tanks and adding foam board. I've got a 1240x.
I have use these fastener to hold a bosshoss 1,200 pds in the floor for a Condon installation they work great :
Self-Tapping Thread Inserts
Pierre Allard is offline   Reply With Quote
Old 04-21-2015, 05:54 AM   #63
Good morning...have enjoyed reading the comments on the Spartan 1032. Will pick ours up in a couple weeks...looking forward to it! Will return the favor and tell of our experiences...when we have had some. Thanks again.
steven1948 is offline   Reply With Quote
Old 05-18-2015, 02:08 PM   #64
We have a 3210 that we picked up in January. So far, everything has worked like it was supposed to. We've had no issues other than the blue lights above the bed that bother my wife, I close my eyes and don't see them. I think my wife is finally happy camping.
Eskimo57 is offline   Reply With Quote
Old 05-22-2015, 07:33 AM   #65
Also own a new Spartan 3210. Haven't had it long enough to learn much about it but did know from the beginning we did not want/need the lower bench/bed in the garage. Took about 20 minutes to get it completely out. Makes the garage area look much larger and "cleaner". Bed on top still goes up and down but now it comes down to where you don't need the flimsy and steep ladder.
Old 05-26-2015, 11:19 PM   #66
We recently purchased a new Spartan 2510.
we have some rather significant problems.
Top 3 are:
- Fresh water tank bracket failed on curb side(tank is down 2-3 inches)
- There are no coaxial cables run to outside junction panel.
- Inside fuel level indicator doesn't work (dealer said there is one outside and the one on the inside is only if you have 2 fuel tanks) Sounds like BS to me.
Is there a way to have both gauges work at the same time? maybe a switch on the outside by fuel pump switch.
Nice trailer but it has a huge list of deficiencies and we hope the it can be fixed without missing too much camping time.
shaunmic is offline   Reply With Quote
Old 05-27-2015, 06:52 AM   #67
Have 2016- 1234x have 2 fuel tanks, one for generator and one for fueling toys. Inside fuel gage only read generator fuel tank, outside gauge have both tanks reading if this may help you.
Old 05-27-2015, 08:17 AM   #68
So there must be a way for them to have both gauges active..
Old 05-27-2015, 06:38 PM   #69
rracer5's Avatar
Beware!!!!! Sounds like you may get less help from your dealer. Prime Time will stand behind their product but only as good as your dealers communication with them (or lack thereof). Be proactive, call PT and ask if certain things ( like the gas gauge) are supposed to be like they are. Then don't take the BS & tell them to just FIX IT!!!
BTW, all the tv stuff ( as well as ALL the other major components) should have been checked during the dealers inspection and shown to you ( working) during your PDI.
:-P
"PT Crew Members Since 9/2010"[/I][/B]
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
Old 05-27-2015, 10:08 PM   #70
They just showed us the outdoor panel and said this is where you hook up your satellite or cable.
And they claim that they don't start the generator.
Sound like they are kinda shifty
$500 for PDI. Don't think they did too much.
I have contacted Rick at prime time and he said it sounds like a wiring issue
I replied and asked if both gauges should work when there is only one tank.
I appreciate the input.
Shaun
