Old 10-08-2015, 01:27 PM   #1
Tilting the awning
We have a 2016 Sanibel 3701 Residential. The awning goes in and out just fine. The problem is it will not angle. It comes out flat and stays that way. There are some knobs that loosen and should let the shiny slotted bars slide into the other tube. The knobs are loose but nothing moves. Any ideas would be welcome.
James Briar is offline   Reply With Quote
Old 10-08-2015, 01:56 PM   #2
strat56's Avatar
Check this video, it should be helpful.
Jack and Jan
Nights camped 2014 - 8 | Nights camped 2015 - 23 | Nights camped 2016 - 24
2015 Ford Super Duty F350 > Blue Ox Swaypro WD Hitch > 2015 Rockwood Windjammer 3008W
strat56 is offline   Reply With Quote
Old 10-08-2015, 02:21 PM   #3
TURBS's Avatar
You actually have to pull down on side you want to tilt and then lock knob.
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "27 nights"
Old 10-08-2015, 04:59 PM   #4
Thanks for the video but my awning is stuck. No matter what you do the slotted piece that should go back into the tube piece won't budge. Like the two sections are jammed. If I pulled down any harder I am afraid something will break. I already knew how it is supposed to tilt but........Thanks anyway.
Old 10-08-2015, 05:11 PM   #5
Get a ladder and look for an obstruction causing them not to slide.
Old 10-11-2015, 04:46 PM   #6
CWSWine's Avatar
Mine is the same as yours. It goes in and out fine but will not tilt like in the video. Mine is not nearly that floppy when extended as the one in the video.
2017 Fleetwood Discovery LXE 40D Diesel Pusher 41 foot. CC 5740
2017 Solitude 310GK-R Pick Up Oct 24th.
2016 GMC Denali 1 ton Cargo Capacity 3722 lbs
Sold 2016 Keystone Montana 3711FL
Sold - 2015 Crusader 315RST 5th Wheel -
2015 Ford F350 SRW Cargo Capacity 3744
CWSWine is offline   Reply With Quote
awning
