Old 11-23-2011, 05:37 PM   #1
Vols's Avatar
Timbrens
Wow! First trip with the timbrens installed and WOW what a big difference! Took the bounce/ porpoiseing totally away. Made trip super enjoyable.
Vols is offline   Reply With Quote
Old 11-23-2011, 07:22 PM   #2
Rugged Brown's Avatar
I'm with ya bro.
Terry/Bernadette
Lily the Yorkie
2015 Dodge Ram Sport 1500
2015 Crossroads Zinger ZT28BH
Rugged Brown is offline   Reply With Quote
Old 11-23-2011, 07:28 PM   #3
Biscuit's Avatar
Sounds like something I would be interested in. Did you just do the rear axle on your truck? How pricey of a system is it? Did you install it yourself?
Biscuit is offline   Reply With Quote
Old 11-23-2011, 07:32 PM   #4
Installed myself, piece of cake. Rear axle only. Total cost $200.
Terry/Bernadette
Lily the Yorkie
Old 11-23-2011, 09:38 PM   #5
Vols's Avatar
Same here (rear only) installed in bout 2-3 min per side. Used dish soAp to lube it up and slid rt on. I still have P rated tires and I can't imagine how much better it can get then this!!
Old 11-23-2011, 09:39 PM   #6
Vols's Avatar
$200.00 (194 before taxes)
Old 11-24-2011, 08:15 AM   #7
Fire Instructor's Avatar
If your truck is more than a year or two old, and you decide to do it, get yourself can of good penetrating oil, then spray the bolts holding the existing spring stops with the penetrating oil every day for a week or so before you do the work.
Removing three of the four bolts and installing the Timbrens on my truck took about 30 minutes... Drilling out and te-tapping the fourth bolt hole - for the bolt that sheered flush with the frame - took about four hours!!!!
Still worth doing, though! I had a MUCH better ride this year while towing, and it was nice when towing at night, to have the headlights actually hitting the road in front of me!
Fire Instructor
2014 RAM 2500 Laramie 4x4 Quad Cab w/Cummins Turbo Diesel, 2009 Rockwood 2607, and 3 'yaks!
300W of Suntech Solar, a Rogue MPT-3024 Controller, and a Xantrex PW2000 Inverter
Fire Instructor is offline   Reply With Quote
Old 11-24-2011, 08:21 AM   #8
No bolts involved in the 2009-12 model 1500. Just pull out the old rubber stops and push in the Timbrens.. The only grease required would be some dish liquid and elbow grease.
Terry/Bernadette
Lily the Yorkie
Old 11-24-2011, 10:16 AM   #9
Davanator's Avatar
Cluelwss
Forgive me for sounding clueless but what are Timbrens and what purpose do they serve and where do you get them?
Davanator is offline   Reply With Quote
Old 11-24-2011, 10:21 AM   #10
Vols's Avatar
Timbren Suspension Kits (SES Kits) are designed to enhance the suspension of your vehicle.
Easiest to Use: Rubber cushions absorb road shocks and automatically adjust to uneven loads or road conditions.
Google them " Timbrens" I was skepiticle but now after traveling with them ,On I'm a believer!!!!!
