Old 11-01-2011, 04:45 PM   #1
Tow Vehicle Tire Pressure
I finally broke down and replaced the OEM tires on my Tundra yesterday. I now have E rated Michelin LT tires. The dealership pressurized them to around 36 psi. The max capable rated load occurs at 80 psi. While I usually run my tires at the max pressure, previously 44psi, I am reluctant to inflate these tires to 80psi. I realize I will not have the max rated load capability at less than 80psi. I probably don't need that capacity anyway. It far exceeds my truck's other limitations. Is there an official recommendation on an appropriate tire pressure to run in my situation? I do realize there may be a limit on the pressure my wheels are rated at. I cannot find that figure either. Please note I am not trying to start another truck capacity thread. Thanks!
James and Karen
Warner Robins, GA
2011 Lacrosse 301RLS
2007 Tundra CM 5.7
Reese Dual Cam
jjarrard is offline   Reply With Quote
Old 11-01-2011, 05:14 PM   #2
Jorman's Avatar
The plate inside the front door of my F 250 states the recommended PSI for front and back. Does yours not show the recommended pressure?
2007 Sierra 301 BHD
2008 Ford F-250 XLT CC 6.4L PS
My goal in life is to be as good a person as my dog already thinks I am.
Jorman is offline   Reply With Quote
Old 11-01-2011, 05:23 PM   #3
acadianbob's Avatar
Your factory wheels may be a limiting factor. I wouldn't pressurize to 80 pounds until I was sure the factory wheels are rated for 80 psi. And make sure you have valve stems rated for 80 psi.
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
2003 Yamaha FJR1300, Demco Premiere Slider
Red Green coffee mugs
Old 11-01-2011, 05:30 PM   #4
Malco's Avatar
I also replaced my Wranglers with Michelin LTX tires yesterday.Dealer told me I should get over 100,000 KMS out of them which would be great considering there was less than 50,000 KMS on the Wranglers and they were getting quite worn. I guess time will tell.
2011 Salem 30kqbss
2013 Ram 2500
2005 Ram 2500
1968 Pontiac Le Mans
Malco is offline   Reply With Quote
Old 11-01-2011, 05:59 PM   #5
The recommendations on the truck's label is for the original tires. I will try 60psi for a baseline. I will keep trying to research the wheel and valvestem limitations. The valvestems have transmitters for the low tire pressure monitoring. Thanks!
James and Karen
Warner Robins, GA
2007 Tundra CM 5.7
Reese Dual Cam
Old 11-01-2011, 06:24 PM   #6
If you still have the stock rims I wouldn't go over 44 (max stock tire psi) until you find out the rim's max rating. You will never need 80 and even 50 should easily cover your max payload + truck weight.
2011 Flagstaff 831FKBSS
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 11-01-2011, 07:42 PM   #7
Triguy's Avatar
The max pressure the wheel can take is usually stamped on the back of the wheel. You might check there first.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 11-01-2011, 07:49 PM   #8
I have run the E rated tires on my 1/2 ton Avalanche at 65 psi for the past 3 years with great results..
2012 Jayco 33 RLDS
2004 Chevrolet Avalanche 2500
2007 TBSS AWD
Hybrid21SS is offline   Reply With Quote
Old 11-02-2011, 05:41 PM   #9
flyrotor's Avatar
Depends if you are running empty or loaded, I would expect that you should be around 40 psi when running around town, maybe 45 psi on the front axle with the weight of the engine,
When you tow, with your truck should probably be around 65 psi front and rear.
Running around town with 65 psi will just make for a bumpy ride.
flyrotor is offline   Reply With Quote
Old 11-02-2011, 06:24 PM   #10
I cant speak for the Tundra but I run the 65 psi front and rear on my Avalanche towing or not and I am not bouncy.
2012 Jayco 33 RLDS
2007 TBSS AWD
