Old 03-27-2013, 08:24 PM   #11
William
WEMig's Avatar
Originally Posted by jtad View Post
I beams, welded directly to the frame. And beefed up a bunch. Yes braking system on the Jeep. There is almost no tounge wieght on the reciever hitch, Of course there is some stress from the Jeep back there, but I bet not as much as when I have my basket that goes in the reciever back there with a cooler in it, or my gennie back there. Works just fine...
I like it. Let me know how the hitch holds up. I have a Crusader and plan on adding a reinforced hitch.
2012 Crusader 320RLT
2011 F250 Lariat 6.7L
2016 (19 Nights Camped/1348 Miles)
2015 (38 Nights Camped/3560 Miles)
2014 (28 Nights Camped/1980 Miles)
2013 (30 Nights Camped/1411 Miles)
WEMig is offline   Reply With Quote
Old 03-27-2013, 08:45 PM   #12
Dave_Monica's Avatar
Great! Sounds like you've got everything covered.
Happy camping...
Dave
Old 03-27-2013, 09:04 PM   #13
jtad's Avatar
Wemig have had the hitch back there for about a year. I regulary carry a rack back there with a huge cooler, It has to wiegh over 100 lbs with everything in it... I also carry a gennie and extra fuel back there that will for prob go 150 lbs. No probs so far..
2011 Cursader 298 BHD
2012 F-250 FX4 6.7 Power Stroke
B&W Companion Hitch
Days Reserved for 2012: 39
jtad is offline   Reply With Quote
Old 03-27-2013, 11:08 PM   #14
Sounds like you did a good job at the rear.
Just watch your pin box area, as I doubt Lippert designed that for the weight of the Jeep back there. They have been known to fail from fatigue.
bakken is offline   Reply With Quote
Old 03-30-2013, 08:53 AM   #15
jtad's Avatar
With the added weight of Jeep I am still only pulling less than 13,000 lbs.
B&W Companion Hitch
Old 03-30-2013, 09:27 AM   #16
All I am saying is that the frame manufacturer didn't design their frames to pull that kind of weight. The pin box area is of special concern. If you could see the light materials used in that structure, it would scare the begeebers out of you.
Old 04-02-2013, 07:11 PM   #17
jtad's Avatar
So your telling me the frame and pin box on my 9,500lbs Crusader is different than a 12,500 lbs Crusader? I don't think so, but I could be wrong.
B&W Companion Hitch
Old 04-02-2013, 07:20 PM   #18
Crusader's Avatar
Wow..and I’m worried about my bike rack receiver I welded on the frame…………
TV= 2012 F-150 FX4 Supercab
FW= 2011 270ret Crusader
Hitch= Reese Pro Series 16K Hitch
Crusader is offline   Reply With Quote
Old 04-02-2013, 08:11 PM   #19
It had better not be the same frame, as that would mean that the manufacturer isn't engineering the frames for the expected load.
Old 04-02-2013, 08:31 PM   #20
LKicklight's Avatar
georgia
Georgia will not allow us to that here..if you are coming through, no one will mess with you..but here as a citizen, would get a healthy ticket and probably have to have it taken apart to get it home...think towing that way would really freak me out...
kicker
LKicklight is offline   Reply With Quote
