Old 03-24-2013, 08:28 PM   #1
jtad's Avatar
Towed the Jeep behind the Crusader
So towed our CJ 7 behind the Crusader to Big Bend for spring break, about a 1,000 miles round trip. Worked out great, installed a camera on the back of the camper so I could keep an eye on the Jeep. You could tell you were pulling a little more wieght, but other than that no change in towing at all. Same fuel mileage as without the Jeep. It tracks right behind the trailer, so it really didn't matter how sharp you turned. Just no backing up with it hooked up.
Name:	the train.jpg
2016 Dynamax DX3 37BH
2015 Jeep JKU
jtad is offline   Reply With Quote
Old 03-25-2013, 07:59 AM   #2
Camper Less Camping
Cajun Po-Boy's Avatar
wow...don't see that kinda combo on the road often
2013 Sabre 32RCTS-6 (sold)
Cajun Po-Boy is offline   Reply With Quote
Old 03-25-2013, 08:21 AM   #3
Golflover's Avatar
What kind of modifications did you have to make?
Golflover is offline   Reply With Quote
Old 03-27-2013, 07:27 AM   #4
jtad's Avatar
Just welded up a reciever hitch, taped into the taillights to run a trailer plug added safety chains and added a camera to keep an eye on eveyerthing.
2015 Jeep JKU
Old 03-27-2013, 07:45 AM   #5
I sure hope you don't have a Lippert frame under that Crusader!
bakken is offline   Reply With Quote
Old 03-27-2013, 08:01 AM   #6
Dave_Monica's Avatar
No braking system on the Jeep?
Dave
Old 03-27-2013, 08:11 AM   #7
TURBS's Avatar
Old 03-27-2013, 08:16 AM   #8
William
WEMig's Avatar
Your reciever hitch welded directly to your bumper or reinforced to the frame I beams?
2012 Crusader 320RLT
2011 F250 Lariat 6.7L
2016 (19 Nights Camped/1348 Miles)
2015 (38 Nights Camped/3560 Miles)
2014 (28 Nights Camped/1980 Miles)
2013 (30 Nights Camped/1411 Miles)
WEMig is offline   Reply With Quote
Old 03-27-2013, 08:33 AM   #9
Good thing it's no longer under warranty.
Old 03-27-2013, 07:41 PM   #10
jtad's Avatar
I beams, welded directly to the frame. And beefed up a bunch. Yes braking system on the Jeep. There is almost no tounge wieght on the reciever hitch, Of course there is some stress from the Jeep back there, but I bet not as much as when I have my basket that goes in the reciever back there with a cooler in it, or my gennie back there. Works just fine...
2015 Jeep JKU
Old 03-27-2013, 08:24 PM   #11
William
WEMig's Avatar
I like it. Let me know how the hitch holds up. I have a Crusader and plan on adding a reinforced hitch.
Old 03-27-2013, 08:45 PM   #12
Great! Sounds like you've got everything covered.
Happy camping...
Dave
Old 03-27-2013, 09:04 PM   #13
jtad's Avatar
Wemig have had the hitch back there for about a year. I regulary carry a rack back there with a huge cooler, It has to wiegh over 100 lbs with everything in it... I also carry a gennie and extra fuel back there that will for prob go 150 lbs. No probs so far..
2015 Jeep JKU
Old 03-27-2013, 11:08 PM   #14
Sounds like you did a good job at the rear.
Just watch your pin box area, as I doubt Lippert designed that for the weight of the Jeep back there. They have been known to fail from fatigue.
Old 03-30-2013, 08:53 AM   #15
jtad's Avatar
With the added weight of Jeep I am still only pulling less than 13,000 lbs.
2015 Jeep JKU
Old 03-30-2013, 09:27 AM   #16
All I am saying is that the frame manufacturer didn't design their frames to pull that kind of weight. The pin box area is of special concern. If you could see the light materials used in that structure, it would scare the begeebers out of you.
Old 04-02-2013, 07:11 PM   #17
jtad's Avatar
So your telling me the frame and pin box on my 9,500lbs Crusader is different than a 12,500 lbs Crusader? I don't think so, but I could be wrong.
2015 Jeep JKU
Old 04-02-2013, 07:20 PM   #18
Crusader's Avatar
Wow..and I’m worried about my bike rack receiver I welded on the frame…………
TV= 2012 F-150 FX4 Supercab
FW= 2011 270ret Crusader
Hitch= Reese Pro Series 16K Hitch
Crusader is offline   Reply With Quote
Old 04-02-2013, 08:11 PM   #19
It had better not be the same frame, as that would mean that the manufacturer isn't engineering the frames for the expected load.
Old 04-02-2013, 08:31 PM   #20
LKicklight's Avatar
georgia
Georgia will not allow us to that here..if you are coming through, no one will mess with you..but here as a citizen, would get a healthy ticket and probably have to have it taken apart to get it home...think towing that way would really freak me out...
kicker
LKicklight is offline   Reply With Quote
