Old 09-06-2011, 03:45 PM   #1
Towing a Crusader 260RLD???
Hi Gang
looking to purchase a Crusader 260RLD. I need some towing advice.
I have a 2006 Dodge 2500, 4x4, cumming diseal, short box vehicle.
I'm concerned about real world pin weight and the payload of the truck. My truck weighs 7500 pounds with a full tank of diseal fuel and my wife and I. The Truck's Gross Vehicle wait is 9000, leaving 1500 pounds for payload or pin weight.
Does anyone have any real world pin weeights they can share with me?, regardless of the model, so i can get an idea what the pin weight for the 260rld will be.
Thank you
Gary
gpscoqn is offline   Reply With Quote
Old 09-06-2011, 04:38 PM   #2
grhodes50's Avatar
to the forum.
It's good that you ask before you buy. It might just save you a few $$.
I can't help you with the real world weights, but according to PT's web site you would be close after loading the 5'er. Especially after you add in 200-250 lbs for the hitch itself.
7500 GVW! Those diesel engines are heavy, aren't they?
Below is the info I found on PT's web site.
Model 260RLD
Base Weight
7,764 lb. (3,522 kg )
Hitch Weight
1,321 lb. (599 kg )
Cargo Carrying Capacity
2,298 lb. (1,042 kg )
Exterior Length
29 ft. 11 in. (9.1 m)
Exterior Height
11 ft. 6 in. (3.5 m)
Exterior Width
96 in. (2.4 m)
Fresh Water Capacity
60 gal. (227 L)
Black Water Capacity
35 gal. (132 L)
Gray Water Capacity
70 gal. (265 L)
Awning Size
20 ft. (6.1 m)
Tire Size
ST225/75R15/D
Here's the link to their Crusader 260RLD web page; Prime Time Manufacturing, Manufacturers of travel trailers and fifth wheels
Gary & Trish
2018 Nights Camped - 5
Old 09-06-2011, 08:26 PM   #3
Originally Posted by gpscoqn View Post
Hi Gang
Thank you
Gary
Gary:
I have a 290RLT with pretty similar weights to the 260RLD you are looking at. I have weighed my truck with the following results:
Actual Rated R-A
Front Axle 4870 5200 330
Rear Axle 3900 6100 2200
Combine 8810 10000 1190
As you can see if you use the GVWR I am over by about 500 lbs as the loaded pin weight of my trailer is 1700 lbs and the GVWR of my truck is 10000 lbs and weighs 8810 lbs loaded before I hitch the trailer. When connecting the trailer to the fifth wheel hitch it virtually adds no front axle weight so all the pin weight goes to the rear axle. I still do not exceed the overall rated axle weight of the rear axle so I am not really concerned and the truck handles the weight extremely well. The only concern I have is this: in the event of an accident where someone pulls out in front of me and I have no chance of stopping even if I didn't have a 10000 lb trailer hitched to my truck, I am sure either the law of some slick lawyer would use this information against me. At the earliest possible moment I will probably be trading my truck for one that will give me some cushion. You do not have much cushion either and I think after you load the trailer you will be over your GVWR also.
Keith & Brenda
2011 Crusader 290RLT
2011 F250 Lariat, Crew Cab, 6.7TD
KAB449 is offline   Reply With Quote
Old 09-08-2011, 07:45 PM   #4
Thank you for taking the time to give such detailed responses.
Gary
Old 09-08-2011, 08:03 PM   #5
grhodes50's Avatar
No problem. Let us know how things work out.
Gary & Trish
Old 09-08-2011, 08:45 PM   #6
M109Rrider's Avatar
Dare I say what I tow with the exact same truck?
Jason and Billie
2005 Dodge Ram 2500, 4X4, QC/SB 5.9L Cummins
15k non-sliding Hidden Hitch (they lied, it's not hidden at all)
2011 Prime Time Crusader 320RLT
M109Rrider is offline   Reply With Quote
Old 09-08-2011, 09:19 PM   #7
M109, yep I would like to know. There are a lot of people that tow a fifth wheel exceeding the payload capacity. Just depends on how you feel about it.
Keith & Brenda
Old 09-09-2011, 05:35 AM   #8
M109Rrider's Avatar
Considering the only thing different between a Fiat 2500 and 3500 are overload springs (which I have) I feel pretty comfortable about it.
Jason and Billie
Old 09-10-2011, 04:36 PM   #9
skgeorgy's Avatar
Fiat. Lol.
Stephen Georgy
2011 Lacrosse 318BHS
2006 F-350
[SIGPIC]
skgeorgy is offline   Reply With Quote
Old 09-10-2011, 05:16 PM   #10
flyrotor's Avatar
Thank you
Gary
Are you sure your weights are right? My 2011 Dodge Ram with Cummins, Crew Cab (4 door) and long bed weighed in yesterday with 3/4 tank of fuel at 7720 pounds.
Have you had your truck weighed? You might want to get an actual weight with full tank of fuel.
flyrotor is offline   Reply With Quote
