02-29-2016, 01:12 PM
Towing Crusader 295 with F150 SCREW EB 3.55 Towing ?
Ok so talked to a dealer about a used 2014 Crusader 295. The hitch weight is 1300, overall weight is 8400. My 2014 F150 has a max tow of 11,200, Payload of 1520. I am getting 10 Ply BFG tires and 2" spacers for front and 2.5" 5000# air lift for rear. Looking at these numbers I should be ok. I do not load my RV's heavy and try to balance them out keeping as much weight off the hitch as possible. Anyone running number like this?
2014 F150 FX4 Crew 4X4 EB
2015 Roo 23IKSS
2016 F350 Supercew Short Box 6.7 PowerStroke Diesel
2013 Crusader 295RST Touring Edition
02-29-2016, 01:14 PM
what is your payload? there is a sticker on your driver door that givers you specific payload.
2015 Ram 2500 4x4 6.4l with 2015 Sandpiper 25RLS
Wife, myself and 2 furry kids
02-29-2016, 01:28 PM
He said 1520
2012 Sandstorm 203slc
2013 Toyota Tundra
Eqil-l-izer hitch,Prodigy P3
2014 Honda Pioneer 700-4
2004 Yamaha Grizzly 660
02-29-2016, 01:34 PM
Yeah 1520 but airbags add 5,000#'s of support so even with the 5er loaded up front I will still be able to tow this unit from all the numbers I see. I am also getting a Reese Slider 12.5K hitch if all goes well
2015 Roo 23IKSS
02-29-2016, 03:55 PM
Airbags do NOT add payload.
All they do is help level.
With your numbers, you only have 220lbs. left over, IF you have NO passengers, NO cargo and NO 5th wheel hitch.
Sorry, but no way you can do it without exceeding payload max.
02-29-2016, 05:01 PM
I tow a 2014 295rst with a 2009 2500hd diesel. As much as I truly like the eb trucks I can't imagine towing my trailer with any less than the 365hp/665tq my truck has. It's a good match but I wouldn't be comfortable with less truck.
2014 295rst champ te
2009 2500hd GMC d/a
2014 295rst TE Champagne
09 GMC 2500HD D/A
02-29-2016, 06:27 PM
Yeah sticking with Roo 23ikss for now will get a used 2015 F350 6.7 in a year or two then upgrade, after crunching all my numbers I don't think I can do a 5er without at least an F350 Diesel
2015 Roo 23IKSS
02-29-2016, 10:02 PM
2015 Roo 23IKSS
I was in the same boat as you until 2 weeks ago. I was towing a fiver with my F150 EB with same exact payload. I could not take my wife or dogs in my car without being overloaded. Driving in separate cars got VERY old. Now I have a 2015 F350 with all of the same Platinum features as my F150 and we are VERY happy. BTW, my F350 gets better fuel economy loaded and unloaded than my Max Tow Package F150 ever did.
02-29-2016, 10:26 PM
Yeah I am looking at trying to get a deal on a leftover F350 Lariat CREW, 6.7, with SB and SRW. I am glad to hear it gets better Economy, but how are the new Power Strokes to maintain? I went with the F150 EB bc I use it as a daily driver and don't want more than one vehicle?
I looked at a 2016 but they won't move from the price that much? Found a Lariat 2016 sticker was $66,000 lowest they claim to come down is $60,000 to me that is not a good deal.
2015 Roo 23IKSS
02-29-2016, 11:59 PM
2015 Roo 23IKSS
If you go to the powerstroke forum, you will see that folks are getting 10k off of the F350's at higher volume/discount dealerships. 60k IS a good deal for the dealer but not buyer.
A couple of weeks ago I did a google search and found several new left over '15 that were being blown out for 13k below MSRP. Not sure if they are around or not but I'm sure you may be able to find a very low mileage '15 and get that or more off of one.
I wouldn't use a F350 as a daily driver unless you have a decent highway commute. Diesels are better suited for long drives and being worked hard. Short trips don't mix well with the complicated emissions system and will cause you lots of grief!
I don't think maintenance is worse than a gasser. My other 2 vehicles are both diesels and I don't do much different than a gasser except I drain the water fuel separator monthly. Turbos get a warm up of 30 seconds to 1 minute and a 1 minute cooldown (5 minutes towing). Not sure where people think that diesels are complicated to maintain. They may be more expensive to repair if something goes wrong but regular preventative maintenance is no big deal.
03-01-2016, 08:57 AM
I towed my 295 with a F250 6.2 gasser for about 10k miles before going diesel. I cannot imagine pulling it with a F150 no matter what engine.
2017 Alpine 3401RS,Titan Disc,Morryde SRE 4000, 2016 Ram 3500HD Laramie SRW,LWB,4X4, Aisin transmission
03-01-2016, 09:54 AM
My daily commute is 95% highway 100 miles per day 2 weeks a month, the rest of the time it sits at home and used for running errands. I am also looking at a slightly used 2015 I figure I should be able to get a 2016 roughly $66K for mid $50K range I would be fine with that Diesel by me is $1.52 per gal
2015 Roo 23IKSS
03-01-2016, 12:34 PM
That 1300# pin weight is very misleading. My 2013 295RST has pin weight of over 2200# with the trailer loaded and ready to camp. Add, that, hitch weight and passengers and you are WAY over GVW for your truck.
Dennis, Linda, and Scout the Dog (RIP)
2015 Mesa Ridge 347 RES
Curt A20
2020 Ram 3500 Dually with HD Cummins TD
03-01-2016, 12:51 PM
Almost anything can TOW it.
03-02-2016, 08:31 AM
The biggest problem with towing a fifth wheel with a half ton is the pin weight. You will always end up using up or going over your payload capacity before you exceed your towing capacity or GCVW. It's one of the reasons I have a bumper pull trailer.
Airbags don't increase your payload. You are then still overloading the rating of your brakes and axles etc.
Orval and Yvonne
2016 Flagstaff 27RLWS Emerald Package
2011 F150 SCrew XTR 5.0L 4x4
03-02-2016, 09:48 AM
I get it problem is I can not justify the cost of a F series Diesel using it 30 nights a year to pull a 5er and a Daily driver. $10-20K less I can keep my EB F150 SCREW and just stick with my Roo. I hardly doubt there will be much of an MPG gain in a diesel driving 1,000 miles per month on the highway, my F150 is getting 21.5 on my 500 mile commute every two weeks so and paying $1.27 per gallon for reg unleaded I can't beat it.
2015 Roo 23IKSS
03-02-2016, 10:45 AM
For reference I am pulling a 295RST with my F150HD. It has a payload of 2177. I am 100% stock and have over 20,000 towing miles. Zero issues. My truck is Max Tow + HD Payload.
IMHO your truck is not suited to this combo. Your payload is your limiting factor largely speaking and there is nothing you can do to increase it. If you are determined to pull with a EB then I'd search for a truck better suited to haul the 295.
2015 F-350 SRW 6.7 PSD
2014 Crusader 295RST
1 Fantastic DW
1 Amazing DD
1 Beagle that will be missed (RIP Zeus)
03-02-2016, 10:57 AM
What's Payload ?
03-02-2016, 11:05 AM
Originally Posted by CAPTAIN MIDNIGHT
What's Payload ?
Well, I'll assume that was in jest. Just don't want this thread to get WAY off track.
Red Green coffee mugs
03-02-2016, 12:09 PM
Do you have the bench seat in yours I can not order a new F150 with Max Payload and Max tow without getting a bench or 40/20/40 seat, I like the center console with shifter in the middle.
2015 Roo 23IKSS
