03-02-2014, 06:21 PM
Engineer of Crazy Train
Tracer 250AIR
Went to both the Boston and Providence shows and liked this floorplan. Anyone out there with one, or similar? What do you tow it with? We liked the floorplan and this onenis on our short list when we get the Ram 1500 Diesel.
Sent from my GT-N5110 using Forest River Forums mobile app
TV - 2015 Ram Truck EcoDiesel
TT - 2015 Rockwood Roo 183 (SOLD due to 2 years off work)
Locomotive Engineer
Nights Camping --- 2015 - 19 Camped | Winterized -- 2014 - 18
Come read my Camping Blogs
03-20-2014, 12:20 PM
We are awaiting delivery of this model. We traded in our 240 air for this floorplan. Its only a little longer/heavier then the 240 but the floorplan is great for kids etc. We will be pulling with 2014 Silverado 6.2L.
03-20-2014, 04:17 PM
Thank you for the response. When you get it, can you post the yellow sticker (you can cut off or blur the VIN). I want to see what the CCC is on it. It looks to be a little lower than I hope for.
Sent from my Samsung Galaxy Note 2 using the FRF mobile app.
Locomotive Engineer
03-20-2014, 04:58 PM
Looks like a nice unit ! I really like the 2014 Silverados. 6.2L is that the 2500HD?
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
Seasonal
Zelda the campin dog
03-20-2014, 07:50 PM
No not a 2500. 1/2 ton but has the 6.2l and max tow package.
03-20-2014, 07:51 PM
Excuse my ignorance what is the CCC?
03-20-2014, 07:58 PM
C cargo C carrying C capacity includes food, water, tools, and any thing else you load!
03-20-2014, 08:02 PM
Ah yes....I believe when I spoke to the PT rep it was around 1200# This is weird because its actually less then my 240?
03-20-2014, 08:19 PM
Always Learning
Makes sense. The CCC is generally the carrying capacity of the axles plus the tongue weight.
Guessing here- they likely have the same axles. Your 240 is smaller and therefore lighter than the 250, so that means it has a higher carrying capacity.
03-20-2014, 08:32 PM
I believe your right on the money. The 250 comes in about 600 pounds heavier on exact same platform which works out on the CCC almost exactly. Looks like I'll have to leave the wife at home!
03-20-2014, 08:37 PM
Always Learning
LOL! Hope she's not a frequent FRF visitor....
03-21-2014, 04:16 AM
Thanks Doug,
This one is #2 on our short list. The Keystone Outback Terrain is #1 on the list. Of course, when the time comes, I will mlst likely be looking used.
Locomotive Engineer
04-04-2014, 08:02 AM
I bought a 2014 250 Air, and could not be happier. Made a few upgrades to enhance my families overall camping experience. Replaced the stock 2500lb scissor jacks with 5000lb BAL jacks and added BAL stabilizer arms. Next I added a slide topper for my one and only slide out due to most of the camp sites we frequent have lots of overhanging trees. Now my camper is solid as a rock and better protected from the elements. I joined this chat group to get good information on my Tracer since this is my families first camper. If anyone else out there with this model has some good upgrade ideas please pass them on.
04-04-2014, 08:53 AM
We are still awaiting our 250 air to come in. What slide topper did you go with and size. I have some upgrades planned as well and took most stuff off our 240 air we traded as they are basically the same trailer. Do you find the 5000lb jacks alone to be a substantial improvement or was it the added stabilizers?
04-04-2014, 09:46 AM
Yes, the 5000lb jacks were a big improvement by themselves, but the added stabilizers made it perfect in my opinion. I went with a 126" Dometic slide topper since my awning was made by them as well. All these accessories were installed by my dealer which you might want to shop around to get the best price. I used Camping World as my base line on parts so my dealer was not going to over charge me. Install is a different story, so I used the fact that Camping World will install the part for $40 dollars if you purchase it from them which put my dealer in check on labor. I hope this info helps. Please let me know what all you did to your 240 Air that I might want to do to my 250.
04-04-2014, 11:09 AM
240 wise I did the PI hard wired surge protetctor, maaxfan with rain sensor auto open and remote, easy drain hot water heater mod, ez ride suspension, combo lock bagage door locks, led lighting. I also upgraded the battery tray to a dual 6 volt system. Im really considering the jacks and slide topper. I already have the maaxfan coming for the 250, a husky brute power jack and all the above to refit on the 250. I always thought the trailer moved quite a bit with the standard jacks.
04-04-2014, 02:15 PM
Yes, my trailer moved quite a bit that is why I did the upgrade. When I got my Camper they had some upgrades that you should be able to choose since you are ordering it, like central vac and power tongue jack which were on my unit when I bought it. On the EZ ride suspension that you mentioned what is that? And what type of LED bulbs did you go with and did they put out enough light? On the PI hard wired surge protector did you have issues with the hum under that bunk or did you install it somewhere else? On the EZ drain hot water heater mod, is it a drain plug you are talking about or is it something else all together?
04-04-2014, 05:57 PM
Tracer Air
We bought an Air 235 and are picking it up Saturday the 11th. We went to the rv show in Cleveland in Feb. We looked at so many campers and walked in the Air and we both knew it was the one.
04-06-2014, 11:46 AM
The led were bought on ebay for cheap but work well. The PI I installed were the main line came in so no hum issues. The hot water drain was simply a braided line attached to a new fitting allowing you to open and drain. We had vac on 240 but never used it not important to us. The ez ride was nice smoothed out the ride but looking back not sure it was worth it. I could have got the power jack option but wanted a different brand not crazy about the brand they use.
Sent from my SM-N900R4 using Forest River Forums mobile app
2016 Wildcat 312BHX
2015 Silverado 3500HD
04-06-2014, 11:50 AM
Maxxfan was definitely worth it.
2016 Wildcat 312BHX
