Old 03-23-2011, 06:24 PM   #1
WJC
Tracer 3000 BHD going back again !!
Brought the trailer in last week because the tires were hitting the wheel wells, My dealer replaced the equilizers giving an additional 1" under the wheel wells! It raised three of the four wheels, but the wheel that had the most damage is still an 1 3/4" from wheel well the front wheel on same side is 3 1/2" from the wheel well, one good bump and the tire will hit! I'm thinking the trailer might be to heavy for suspension, maybe this is why this trailer was discontinued! This will be the fifth time the trailer is going back, like the trailers set up but having mixed feelings!
WJC is offline   Reply With Quote
Old 03-23-2011, 06:30 PM   #2
M109Rrider's Avatar
That sux, Hope you get it figured out.
Jason and Billie
2005 Dodge Ram 2500, 4X4, QC/SB 5.9L Cummins
15k non-sliding Hidden Hitch (they lied, it's not hidden at all)
2011 Prime Time Crusader 320RLT
M109Rrider is offline   Reply With Quote
Old 03-23-2011, 07:02 PM   #3
It sounds like it is time to involve the factory...5 times..maybe it should be taken back to the factory and fixed properly....put a heavier suspension off a Lacrosse on it or something. ...I would be very surprised if Prime Time does not do something to help you out. Have you talked to Brandon?
2011 Lacrosse 318BHS Touring Edition
2012 Ford F150 SupCrew 4x4 XLT 6.5' Max Tow
padave65 is offline   Reply With Quote
Old 03-24-2011, 08:14 PM   #4
WJC
Hi,
Yes I've talked to Brandon and he's been great, he asked me to send pictures and he has the parts at the dealer when i bring my trailer there. I just sent more pictures, he thinks its the leaf springs and is sending a new one to dealer, there costumer service has been great and I do like my trailer set up! Hopefully this will solve the problem!!
Old 03-25-2011, 06:19 PM   #5
I hope they get it fixed before camping season....
Old 03-27-2011, 01:29 PM   #6
grhodes50's Avatar
Hang in there. I know what it's like to spend thousands of hard earned money on a trailer and then continually have to take it back for repairs. It does appear that Prime Time genuinely cares and wants to make sure everything is corrected properly. I'm betting they will get things fixed for you.
Good luck.
Gary & Trish
2018 Nights Camped - 5
Old 03-31-2011, 09:48 AM   #7
WJC
Talked with Brandon and sent some pictures of the suspension, he said it looks like the spring had flattened out and would send a new one to the dealer. Went on Tuesday and when the mechanic looked at the wheels they were both between 21/2 to 3" from the well. He said the new equalizer could have been to tight when installed not allowing it to pivot and the ride over here worked it in! Well I think its time to try it out!! Can't say enough about there costumer service, they do stand behind there product!
Old 03-31-2011, 03:10 PM   #8
M109Rrider's Avatar
I'll buy that for a dollar but.......man, that sucker must have been SUPER TIGHT
Jason and Billie
Old 03-31-2011, 07:57 PM   #9
WJC
I'm hoping that was the problem ! After leaving the dealer rode around for about an 1 1/2 than checked wheel wells and everything was ok. I guess the big test will be the first trip this month! But I think everything will be fine!!
Old 03-31-2011, 09:30 PM   #10
grhodes50's Avatar
Good to hear they got you fixed up.
Now go have some fun!
Gary & Trish
