Old 07-25-2011, 12:54 PM   #1
mhuffs9017's Avatar
Tracer 3150bhd Bunk House TV mount
Just wondering if anyone has mounted a flat screen in the entertainment area of the bunk house. I've considered doing so but not sure if the construction would warrant me having to install something to attach the mount to. Does anyone know if this area has anything that could server as an anchor point?
2013 F350 DRW 6.7 3.73 - Lariat Ultimate FX4 - Tuxedo Black - 14K GVWR
2013 Sabre 36QBOK
2012 Rinker 246BR - "Off The Grid"
Nights Camped 2013 - Not enough!
mhuffs9017 is offline   Reply With Quote
Old 07-25-2011, 01:29 PM   #2
sfrye5853's Avatar
Does your floor plan have the TV area in the middle of more on the back side? We have the Tracer 3150BHD which is essentially the same floor plan, but they had a mid-year change and placed a counter top on the back side... so from left to right we have the wardrobe door, the ladder, then the counter top with drawers under it. I'm looking at a surface mount TV holder that I can just secure on the counter top.
2005 Ford Expedition 5.4 4x4
2012 Tracer 3150BHD
sfrye5853 is offline   Reply With Quote
Old 07-25-2011, 01:34 PM   #3
mhuffs9017's Avatar
Ours is in the same place as yours, toward the back, wardrobe, ladder, counter top. Great idea about mounting to the countertop! Off to monoprice.com I go, best and cheapest place online for this type stuff.
2013 Sabre 36QBOK
Old 07-25-2011, 01:35 PM   #4
sfrye5853's Avatar
In looking at it, it seemed like you might want to swing it out a bit to give everyone a chance to see in unobstructed. I thought an actuating arm that allows you to fold it back again the wall for travel, and out for viewing would be the best bet.
2012 Tracer 3150BHD
Old 07-25-2011, 01:38 PM   #5
mhuffs9017's Avatar
Think I found one, at $8 it's worth a shot.
For only $7.00 each when QTY 50+ purchased - LCD LED Cabinet Mount Bracket - Black | Ceiling / Under Cabinet Mounts for Flat Panel Displays
2013 Sabre 36QBOK
Old 07-25-2011, 01:41 PM   #6
mhuffs9017's Avatar
How will you mount this to the counter? Send me a link if you got one to what you were thinking. I'm more concerned with just securing it for travel rather than have to take it out and lay it somewhere each time.
2013 Sabre 36QBOK
Old 07-25-2011, 02:11 PM   #7
On my LaCrosse 318BHS, (same basic layout) I mounted a 23" Samsung LCD back there. I used some short 2x4's stained to match the interior to attach the LCD mount to. I basically screwed the 2x4's to the wall framing and then used those to attach the mount to with short screws.
Once the TV was mounted, you cannot even see the 2x4 blocks and its very sturdy.
Hope this helps,
John
2011 Primetime LaCrosse 318BHS Touring Ed
Joined the PT family on 10/2010
2006 Chevrolet 2500HD 4x4 T/V
John
foxhead is offline   Reply With Quote
Old 07-25-2011, 02:24 PM   #8
mhuffs9017's Avatar
Hope this helps,
John
Hey John - how did you locate the wall framing? Stud finder? If so, is this aluminum studs or wood? What type of screw did you use to secure the 2x4's?
2013 Sabre 36QBOK
Old 07-25-2011, 02:27 PM   #9
You could use a stud finder, but they're really easy to find behind the thin wall paneling. My studs were wood in that area. Basically right behind the outdoor kitchen...
I used a 2.5" deck screw to secure the 2x4 to the wall. I then used a 1.25" deck screw to attach the tv mount to the 2x4..
John
John
Old 07-25-2011, 02:28 PM   #10
mhuffs9017's Avatar
John
Excellent, thanks for the input! I'll open the cabinets in the outdoor kitchen to see where they attached. Make this a fall project, too darn hot to work in there now!
2013 Sabre 36QBOK
tv mount
