Old 11-15-2014, 10:01 PM   #1
Tracer roof seal failing
After winterizing and prepping my tracer 3150 for winter, I climbed on the roof to apply our new ADCO cover and noticed the caulking seal at the front of the trailer was cracking, as if it wasn't properly adhered. I called my dealer and was told that even though I was still under warranty, the issue fell under "customer maintenance".
I'm a little puzzled since the unit isn't even a year old, and never thought that the caulking was a "maintenance" item that had to be addressed every year. Yes, it should be checked and fixed if needed, but after a year???
After two trips back to the dealer with simple warranty issues, their demeanor on this issue was, well less than rather to help.
Please take a look at the pictures and tell me if this is something I should Pursue with the dealer, or Prime Time. Click image for larger version
Name:	ImageUploadedByForest River Forums1416106780.012366.jpg
ID:	66463Click image for larger version
Name:	ImageUploadedByForest River Forums1416106808.061706.jpg
I have no issues with maintaining my toys or equipment, but it just worries me that the factory job doesn't even last a year.
2014- 25
Agewon is offline   Reply With Quote
Old 11-15-2014, 10:33 PM   #2
I hope you took care of that before you parked it for the winter, that should not happen so soon but from the pics they did a crap job at the factory you can see parts of the strip, I think that should be all covered with sealant. I have not had a good time dealing with the my dealer or PrimeTime so I just take care of things myself to make sure they get done correctly because they don't care(they already have your $$$) its a shame its that way but most of the people I talk with are having the same problem with dealers and the manufactures!! I just started to reseal my roof this fall using Sikaflex 715 but the factory sealant is still in good shape after almost 2 years but I don't want to take any chances with water, it always will find a way in!!!!. good luck and as I always say keep a eye on it. Keepaeyeonit
2014 Crusader 335BHS-TE
2017 F-350 6.7L CC flat bed
Nights Camped in this unit.
2017 3 so far
2015 57/2016 52
2014 40/2013 38
keepaeyeonit is offline   Reply With Quote
Old 11-15-2014, 10:40 PM   #3
Unfortunately, I just saw it today when putting the cover on. I had been on the roof about a month ago and didn't notice anything, but then again my eye hadn't been trained on looking for issues.
I just put on a new all climate ADCO cover that I hope will keep it dry until I can address the issue, hopefully soon.
2014- 25
Old 11-15-2014, 11:17 PM   #4
If I were you I would pull the cover ASAP and get some sealer on that roof, don't let that go though the winter like that or your asking for trouble. Cracks on the roof is a bad thing!!! Keepaeyeonit
2017 3 so far
2015 57/2016 52
2014 40/2013 38
Old 11-15-2014, 11:30 PM   #5
Campin Cajun's Avatar
Take this with a grain of salt, but a dealership tech told me that caulking is only warranted for 6 months. And no, dealerships do not mention this fact about customer maintenance. It is nowhere in the service manuals either.
2013 Berkshire 390BH
Campin Cajun is offline   Reply With Quote
Old 11-16-2014, 01:05 AM   #6
Platokidd's Avatar
I caulk a few areas on my 2014 lacross before covering. Normal maintenance. But that does look bad. Need to inspect your roof a few times a year.
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
Seasonal
R.I.P. Luke the campin dog
Old 11-16-2014, 03:35 AM   #7
Witch Doctor's Avatar
That factory seal job looks like crap, a two year old could have done better. I never heard of that it is not a warranty item before.
Coachmen M/H
Concord
2018 / 300 DSC
Witch Doctor is online now   Reply With Quote
Old 11-16-2014, 02:58 PM   #8
rracer5's Avatar
That looks like it was a bad batch of sealant. That stuff is not supposed to "shrink" (that's what it looks like it did) as soon as it did. All sealants/caulking will deteriorate due to exposure to the elements eventually but, this appears to be too soon.
X2, on getting something up there quick. Once water gets in between something it can never dry before mold starts.
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
Old 11-17-2014, 09:13 AM   #9
I just spoke with Prime Time warranty tech and explained that my roof sealant had a major failure. He told me that they don't use roof sealant. He then went on to tell me that the roof has a 12 year warranty and its covered. So i had to elaborate and ask him what was used around the antenna and vents etc, and he said "sealant". Its as if the guy wasn't even listening to me when i spoke. I asked him if i could send pictures so he could see how bad the failure is and he told me not to, and to submit a claim through the dealer. Crazy!
I then called Dicor and asked if they would review the pictures and tell me their thoughts, and Kathy was VERY pleasant and helpful.
I must have done at least 8 check this year on the roof. the last check was after our last trip in October and everything was fine. How can something this bad happen in 1 months time? After looking closer, i thing its either due to improper preparation or it was applied in cold environment and wasn't allowed to "flow" properly creating an air pocket below.
I have 3 tubes of Dicor coming today, and i can only pray that there hasn't been any damage inside.
Honestly, this is the most frustrating thing in the world. its like buying tires with a 50K mike warranty and the treads are only guaranteed for 90 days.
Old 11-17-2014, 09:07 PM   #10
Platokidd's Avatar
Agewon,
who did you talk to at prime time ?
Seasonal
roo, roof
