Old 11-13-2011, 08:06 PM   #1
TV Mount
Does anyone have the ceiling TV bracket in the bedroom of the Lacrosse or Tracer? If so, do you like it? I was going to order one for my Tracer. Thanks, Coltsfan
coltsfan is offline   Reply With Quote
Old 11-14-2011, 03:02 PM   #2
I have it and my wife and I like it. You can easily control the viewing angle....in addition that tv is easily removed to go outside with it.....It also allowed my Lacrosse to have solid wood doors to the bedroom. I think it was a great idea.
2011 Lacrosse 318BHS Touring Edition
2012 Ford F150 SupCrew 4x4 XLT 6.5' Max Tow
padave65 is offline   Reply With Quote
Old 11-15-2011, 10:32 AM   #3
rracer5's Avatar
Is or was there a sticker on the ceiling letting you know that a Tv mount could be installed there? If not, then there may not be proper backing in the ceiling to hold the weight.
"PT Crew Members Since 9/2010"[/I][/B]
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
Old 11-15-2011, 06:14 PM   #4
Good point
Old 11-18-2011, 06:47 PM   #5
I bought it used. No sticker, but the antenna jack and plug are in the ceiling over the bed. I will have to double check this. Thanks for the replys. This forum is great!
Old 11-18-2011, 07:21 PM   #6
Malco's Avatar
A little off topic but we have a tv mounted in a cabinet that can be viewed from the living area or spun around and viewed from the bedroom.The tv came installed in the trailer.My question is does anyone know how to take the tv out.I thought maybe it would lift up and pull out but this is not the case.
2011 Salem 30kqbss
2013 Ram 2500
2005 Ram 2500
1968 Pontiac Le Mans
Malco is offline   Reply With Quote
Old 11-20-2011, 08:07 PM   #7
rracer5's Avatar
I think the ceiling mounts just came out recently so, if your TT is a few years old, the Tv was probably intended to be mounted on the wall just below the jack and plug. The walls on TT's are very thin and if you push on the wall in that area and it feels solid, then there is probably a backer behind the wall to attach the mount to.
2014 Sanibel 3250
Old 11-25-2011, 02:18 PM   #8
Vols's Avatar
Malco- we have tracer 3150bhd with same tv set up. Un plug it and lift straight up. It wiill slide off bracket and we can move to out side tv mount. ONLY THING IS... it is hard as heck to fish power cord back through behind stereo to get plugged back in! We just bought another tv for bunk area and move it to outside when we need it.
Vols is offline   Reply With Quote
tv mount
