Old 11-24-2013, 07:21 PM   #11
Ford Idaho's Avatar
Originally Posted by Midwestgirl View Post
So...by now the guys fully understand I'm a novice with a 5th wheel. No worries, I will learn to manage the rig fine! If I get a lube plate where do I put it? Under the pin? Or is this installed by a tech? How often should I replace it? What's the general consensus on lube plates verses greasing? I'm willing to try anything that makes this process easier for me. Thank you.
The one I bought just slips onto the pin and is held in place by little fingers that grip the pin.
If you look at the one I posted you will see it works the same way.
You can DIY if you wish, when hooked up the pin will keep it in place.
I do not know how long they will last, but they are way cleaner.
Old 11-24-2013, 07:23 PM   #12
rracer5's Avatar
Originally Posted by SteveBingham52 View Post
We have always used the lube plate. We just leave ours on the kingpin.
Clean off all the grease on the pin and hitch plate. Install the lube plate on the pin (may have to tap it in place & it will stay in place) Now, get rid of the laundry bleach cause you won't get grease on your clothes any more.
"PT Crew Members Since 9/2010"[/I][/B]
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
Old 11-24-2013, 07:29 PM   #13
Midwestgirl's Avatar
Your advice is well received. I will find a plate this week, we are in Laughlin. Or have my son bring one in 2 weeks when he flies out to visit. I am reading all your helpful replies to my husband and he is VERY appreciative of your knowledge and willingness to share with us. We pulled TT for years and everything was smooth sailing. In trying to reach our selling dealer a few times with questions I felt like I was taking up his time. He told me to call anytime for help, that was BEFORE I wrote the check! So, many thanks tonight, I am feeling more confident now that I know exactly what to expect and you guys are here for back up support.
Midwestgirl
2005 K-2500 Silverado 8.1L 6 speed Allison
Midwestgirl is offline   Reply With Quote
Old 11-24-2013, 08:19 PM   #14
Rebel702's Avatar
Midwestgirl,
I am in Las Vegas for the winter so if you need any assistance give me a PM. A ride to Laughlin is a fun day.
Rockwood Windjammer 3002W (11/10/2011)
2011 Sierra Denali HD - Duramax/Allison
EQ-4, 14,000/1,400
2006 Yukon Denali
Rebel702 is offline   Reply With Quote
Old 11-24-2013, 08:23 PM   #15
Fulltime family RVer
Yes, I do watch for the separation for about an inch or less. I will back it flush next time as suggested and then pull. Or put in neutral and use emergency brake as suggested. We are moving to a really neat site on Friday morning so will try your suggestions. Should I be greasing the plate...how often? Or what product do you suggest? Thanks...
You said you look for a separation of "an inch or less" - I almost wonder if you're shooting for too much separation. As OldCoot said, you only need 1/8"-1/4" (e.g. just seeing daylight between them). You're not looking for a lot of space.
Another vote for a lube plate. No mess, no fuss and it'll last for years. They're usually $15 or so from RV stores.
ependydad is online now   Reply With Quote
Old 11-24-2013, 08:29 PM   #16
golfmedik's Avatar
Get a quality plate like Reese for example. I damaged one of mine and replaced it with a no name brand and it didn't last 2 months. There are some very cheap ones out there.
2012 Sandpiper 365SAQ weighing @ 15k, Onan, 2nd air, slide toppers, TST
2013 F350 6.7L Lariat 4x4 CC DRW,Viair 1007, Ride-Rites, Edge CTS, B&W
2001 Chevy 3500CC DRW 4x4, 8.1L, 4.10 gears w/ Detroit TrueTrac
2001 Ford Excursion Limited 4x4 7.3L,V/B Spring Mod, ProComps, Hellwig Swaybar, & other 'Necessities'
golfmedik is offline   Reply With Quote
Old 11-24-2013, 09:09 PM   #17
Sounds good on buying a quality plate and sounds good on separating enough to see light! 1/8 to 1/4 inch! And okay Rebel702 for a road trip if I need help. WOW! Thanks!
Midwestgirl
Old 11-24-2013, 09:19 PM   #18
John McClain's Avatar
I use a lube plate to but remember it does absolutely nothing to help the jaw and pin for lubrication that's a big wear point. I do put a little grease on my king pin. Chock the tires both sides now Just lower the landing gear making sure they are even till you see a small gap between the plates about 1/2 inch to much gap puts the king pin in a bind with the jaw . You should be able to rock the trucks fifth wheel plate side to side and front to back about a half inch or so, if its not in a bind. If it's in a bind just shift to N than back to park and check the plate agian. I had a low bed service for years and have been playing with this stuff a long time. (GREASE YOUR PIN)
F-250 . stealth 3210 solar pannels, fantastic fans. and life line batteries
John McClain is offline   Reply With Quote
Old 11-24-2013, 09:58 PM   #19
Chewie's Avatar
I have a Curt Q 20, mine has several grease fittings for periodic maintenance. I use a full synthetic grease and it releases good. I had an issue like you described early on and when I got it release I greased it and haven't had any further issues. I also use a lube plate, only grease where it says to. Mine has stickers with arrows pointing to the grease points that make it easy.
I used to have a really nice motorhome
2016 Jeep Wrangler Unlimited
Chewie is offline   Reply With Quote
Old 11-25-2013, 09:57 AM   #20
Lubing the jaw mechanism is a must to keep smooth operation. I have a pullright and they recommend WD40 for the parts. I used a product called HHS, it sprays on like WD40 and gels up. Creates a nice long lasting barrier.
jbrostek is offline   Reply With Quote
5th wheel, wheel
