Old 11-25-2013, 10:13 AM   #21
BamaBob's Avatar
Originally Posted by Midwestgirl View Post
So...by now the guys fully understand I'm a novice with a 5th wheel. No worries, I will learn to manage the rig fine! If I get a lube plate where do I put it? Under the pin? Or is this installed by a tech? How often should I replace it? What's the general consensus on lube plates verses greasing? I'm willing to try anything that makes this process easier for me. Thank you.
My vote is for a Lube Plate. Here is a amazon link for one:
Amazon.com: Reese Towpower 83001 Signature Series Fifth Wheel Lube Plate: Automotive
If you want to continue to use grease, I have a can of ball grease and a can of lithium grease I will be happy to send you
As to frequency of replacement...no Idea (bet OC knows!) Looking at ours though I would guess a annual - maybe semi-annual task. If you want to call it that - the plate just pops on the kingpin and self seats the first time you hitch up! Could'nt be easier and NO greasy mess!
Nights Camped: 2013 - 24 • 2014 - 42 • 2015 - 56 • Jul 2016 - Fulltime •
BamaBob is offline   Reply With Quote
Old 11-25-2013, 10:19 AM   #22
Originally Posted by HSVBamaBob View Post
...As to frequency of replacement...no Idea (bet OC knows!) Looking at ours though I would guess a annual - maybe semi-annual task. If you want to call it that - the plate just pops on the kingpin and self seats the first time you hitch up! Could'nt be easier and NO greasy mess!
Have no idea, I activated the Reese Revolution hitch and don't need or use one. The pin does not swivel on the hitch, the trailer swivels 22" back on the stationary pin box.
Old 11-25-2013, 10:34 AM   #23
I have a Hijacker auto slide. I put chocks behind the trailer wheels, backup, put on the emergency brake, shift to park. Now no pressure on the pin, release handle slides and turns easily, put landing legs down, disconnect and pull away. Before this technique I had a heck of a time unhooking the trailer.
Bob & Sharon, '18 Berkshire 34QS, 2018 Jeep Cherokee.
btritschler1437 is offline   Reply With Quote
Old 11-25-2013, 11:16 AM   #24
Hoo Dad's Avatar
Interesting. I've had my original lube plate on since January 2011 (almost 3 years and approximately 17,000 miles). I notice almost no wear. There are probably a lot of variables as to how long it will last.
2011 Rockwood 8285 WS
2011 GMC 3500 HD 4X4, 6.0, 4.10, SRW
Hoo Dad is offline   Reply With Quote
Old 11-25-2013, 12:15 PM   #25
Lloydg's Avatar
Send a message via AIM to Lloydg Send a message via MSN to Lloydg Send a message via Yahoo to Lloydg
Originally Posted by jbrostek View Post
Lubing the jaw mechanism is a must to keep smooth operation. I have a pullright and they recommend WD40 for the parts. I used a product called HHS, it sprays on like WD40 and gels up. Creates a nice long lasting barrier.
X2 It's probably best to review the manufacture's recommendation for the hitch you have. For my Reese 18K Elite slider hitch, the recommendation is to use white lithium grease.
Heartland Big Country 3150RL
2013 Ford SD F250 4x4 SC; 6.2
Reese 18K Elite w/slider - Ada, Michigan
Lloydg is offline   Reply With Quote
Old 11-25-2013, 02:10 PM   #26
BamaBob's Avatar
as a scientist I LOVE empirical data! Thanks for the observation!
Ours is brand new and I was just making conjecture (read a SWAG
Old 11-25-2013, 03:31 PM   #27
Grape Escape
5 years wear on my lube plate and no signs of any wear at all. Would not consider any other method period. Sounds like you were lifting trailer too high off the plate. As others mentioned raise front just till you see daylight.
Be sure to get the proper diameter for your hitch as my Reese signature series required a 10" diameter and there are smaller ones available
2008 Cardinal 30RKLE 5th wheel sold
2006 Rockwood 2607, 2001 Traillite
55 nights 2009, 53 for 2010
44 for 2011, 38 for 2012, 35 for 2013, 51 for 2014
dezolen is offline   Reply With Quote
Old 12-03-2013, 09:40 PM   #28
Midwestgirl's Avatar
An update: I moved our 5th wheel last Friday to another campground and followed
each step carefully without any problem. All went smooth! My error with unhooking was raising too high. thank you everyone!
Midwestgirl is offline   Reply With Quote
Old 12-04-2013, 04:27 AM   #29
golfmedik's Avatar
And now starts to where you can give other people friendly advice that has been "your experience"!! Nice job!
2012 Sandpiper 365SAQ weighing @ 15k, Onan, 2nd air, slide toppers, TST
2013 F350 6.7L Lariat 4x4 CC DRW,Viair 1007, Ride-Rites, Edge CTS, B&W
2001 Chevy 3500CC DRW 4x4, 8.1L, 4.10 gears w/ Detroit TrueTrac
2001 Ford Excursion Limited 4x4 7.3L,V/B Spring Mod, ProComps, Hellwig Swaybar, & other 'Necessities'
golfmedik is offline   Reply With Quote
Old 12-04-2013, 05:47 AM   #30
sail2liv's Avatar
Still using the used lube plate old coot gave me a couple of years ago....so for me is the only way to go.....but I do keep a thin coat of grease on the pin where it contacts the jaws of the hitch....also a thin coat on the jaws where the pin contacts them when hooking up.....but the hitch is covered by the bed cover so no big amounts of dirt coming in contact with grease.....good luck with your new adventure.
2011 Silverado 2500HD 6.0 Gas 3.73
2013 Flagstaff 8524 RLWS
1978 Cape Dory Ketch
sail2liv is offline   Reply With Quote
5th wheel, wheel
