Old 05-08-2011, 09:18 AM   #1
tbritt's Avatar
Up date 303rk
Well the new breaker the Dealer put in didn't make it past it's first 90 degee Texas day.....Guess we'll put the Frig and Water heater both on gas to see if it will hang in there until the Dealer/PT get it all worked out, other than that it's the same ol story,Parts on order checks in the mail!!!Happy Mothers Day to all the PT DW's
2012 GMC 2500 HD
2011 303 RK LaCrosse Luxury Lite
Days camped 2010: 274
2011: 365
2012: 365
tbritt is offline   Reply With Quote
Old 05-08-2011, 11:31 AM   #2
grhodes50's Avatar
I'm not much on electrical problems, but I do know they can be hard to trace down. I would think replacing the breaker would be the easiest and probably the first thing to try. After that, I guess just take things one at a time until whatever is tripping the breaker can be found. Time comsuming and not always easy to do.
Hang in there and I hope they find the problem soon.
I found out why my dealer hadn't ordered the parts. The service manager has been out because of serious illness. He hadn't ordered the parts yet and no one could find the list. He's back now and the parts were ordered the other day. Just one of those things. At least the service manager is doing well enough to be back at work.
Gary & Trish
2018 Nights Camped - 5
Old 05-08-2011, 11:33 AM   #3
rracer5's Avatar
Sounds like it's time for a new Power Center.
BTW ..... Did you get my answer to your post about your need for a TV mount?
"PT Crew Members Since 9/2010"[/I][/B]
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
Old 05-08-2011, 03:08 PM   #4
M109Rrider's Avatar
May or may not be the right answer and/or what you want to hear but my old trailer was the same way. I had to limit what electrical stuff would be on at the same time as the A/C. I couldn't run the A/C and water heater and I had to make sure the coffee pot was off before using the microwave. The problem I had was when the A/C cycled. If I used the stuff while the A/C was already running it wasn't a problem. But if the A/C was off and cycled on the initial current draw would trip the breaker. I had to accept that's the way it was and got used to it.
Jason and Billie
2005 Dodge Ram 2500, 4X4, QC/SB 5.9L Cummins
15k non-sliding Hidden Hitch (they lied, it's not hidden at all)
2011 Prime Time Crusader 320RLT
M109Rrider is offline   Reply With Quote
Old 05-09-2011, 07:05 AM   #5
Is it the power source or does the AC or Frig have issues? Did anyone hook them up to make sure they are working properly?
2011 Lacrosse 318BHS Touring Edition
2012 Ford F150 SupCrew 4x4 XLT 6.5' Max Tow
padave65 is offline   Reply With Quote
Old 05-09-2011, 08:41 AM   #6
tbritt's Avatar
Yes and thanks I just haven't got to call Brandon with all thats going on the TV mount went on the back burner, but will call him
2012 GMC 2500 HD
2011: 365
2012: 365
Old 05-09-2011, 08:55 AM   #7
Wanna Be Camper
SaskCampers's Avatar
Just curious, do you have a 13.5 or 15k A/C unit? If it is a 15k maybe too much current on the cct with the water heater.
John & Deb
2011 Flagstaff V-Lite 30WRLS
Days Camped 2016: 3 2017: 0
Old 05-09-2011, 09:02 AM   #8
tbritt's Avatar
Yep it's a 15K but you would think if they tested all the systems and ran across a issue they would have made this trailer a 50 amp. It makes sence that you should have no trouble with the 3 big draw items A/C,Frig and Water heater??
2012 GMC 2500 HD
2011: 365
2012: 365
Old 05-09-2011, 09:15 AM   #9
grhodes50's Avatar
I have the same tt as you, but I haven't camped needing to run the AC yet. I have ran the furnance without issues, but that's not the same as the AC.
I will be camping in a couple of weeks and I anticipate I will be running the AC then. I will let you know if I have the same issues you are experiencing.
Gary & Trish
Old 05-09-2011, 09:38 AM   #10
Wanna Be Camper
FYI
  • Air Conditioner 15-17 amps
  • Refrigerator 5.7 amps
  • Electric Water Heater 12.5 amps
  • Microwave Oven 12.8 amps
  • Electric Coffee Pot 9 amps
  • Toaster 10 amps
  • Hair Dryer 10-12 amps
  • TV 2 amps
  • Dirt Devil Hand Vacuum 2 amps
  • Electric Fry Pan 10 amps
  • Iron 10 amps
  • Food Processor 6 amps
  • Crock Pot 1.5 amps
  • Heating Pad 0.5 amps
  • 1,100 Watt Heater 10 amps
  • Laptop computer 2-3 amps
John & Deb
