Old 03-03-2016, 05:20 PM   #1
Upgrading fifth wheel concerns
We are currently full timing in a 32 ft Crusader. We are looking to upgrade to a 36 ft fifth wheel. I am concerned of towing the extra weight and getting into different campgrounds as we are touring the country. Any feedback would be helpful
brireey is offline   Reply With Quote
Old 03-03-2016, 05:24 PM   #2
Kenny kustom's Avatar
What do you tow with??
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
2017 Dynamax Isata 4
Old 03-03-2016, 05:50 PM   #3
SeaDog's Avatar
I think if you measure your overall length (tow vehicle and rig bumper to bumper) you may find that a 32 bumper pull which I'm assuming the crusader is as long or very close to the overall length of a 36 fifth wheel. My 26' TT has an actual length of 29'
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 03-03-2016, 05:58 PM   #4
Thanks for replying Kenny KustomThe Crusader is a fifth wheel do I will be increasing my length by 4 ft and weight by about 4000 lbs
Old 03-03-2016, 05:59 PM   #5
B and B's Avatar
Truck you use to tow with? Specs etc..
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 03-03-2016, 06:10 PM   #6
The truck should be ok for the weights it is an F350 6.7 Diesel but not a dually.
Old 03-03-2016, 06:19 PM   #7
With a 350/3500series SRW keep your fiver GVWR under about 14,000 pounds and you should be OK. As for the added OAL length, remember that fiver will actually be shorter length behind the truck. So no problems there.
To just be positive on weights, take the proposed trailers GVWR, 20% of which is generally agreed is pin weight. Add thst number to your trucks scaled ready to travel weight. As long as that total is under your trucks GVWR as listed on the drivers door post, you should be fine.
donniedu is offline   Reply With Quote
Old 03-03-2016, 07:24 PM   #8
Rupkin2's Avatar
We have the Crusader 320 RLT. Overal length from pin to bumber is 36.5'
The dry weight is 10245 lbs, 1753 pin weight.
Remember, compared to a pull trailer of same length you will be approx. 4' shorter overall due to the overhang over the box.
With a 36-37' 5th wheel your over length will be fairly close to what u are pulling now.
Weight will not be a problem for your 350.
Final thought, my Chevy 2500 pulls the trailer no problem and these trailers are balanced very well, I don't get any sloppy truck bouncing when going over bumps, rail tracks.
John
07- Classic 2500 LT CC 4x4 SB Duramax/Ally
13-320RLT Crusader TE
Reese 16K Kwik Slide/Prodigy brake contoller
Rupkin2 is offline   Reply With Quote
Old 03-04-2016, 11:56 AM   #9
lckeehne's Avatar
I have a 34' 5th wheel. This is the max for most California state and national parks that I know.
Yosemite. There are only 6 sites to handle 34 trailer.
lckeehne is offline   Reply With Quote
Old 03-04-2016, 12:22 PM   #10
zs325RES's Avatar
We have the Crusader 325RES (+37') and have to think twice about where I plan to camp.
There are MANY state parks here in Michigan that I simply do not consider because of my length. Instead, we have happily been frequenting RV parks which accommodate our size with no issues.
I visited a well known county park in St. Petersburg, FL last week (Ft. DeSoto) just to see what it was like. I saw a new 32' Crusader there and I questioned how they got it into their spot. Barely room for the slide-outs.
My setup (see sig) works great for us. The Crusader pulls like a dream and my truck performs very well.
2013 Crusader 325RES Touring Edition
2006 Silverado 2500HD LT SW ECSB, 6L LQ4/4L80E 4.10s w/16K Curt slider (not necessary), Air Lift bags & Black Bear Performance tune & CAI
Norm & Karen Zondervan
zs325RES is offline   Reply With Quote
fifth wheel, wheel
