Old 12-06-2011, 01:17 PM   #11
Rugged Brown's Avatar
Originally Posted by RV Guy View Post
Great question - this has been the source of alot of discussion at all of our plants the last 24 hours as we've found a couple of different ways that it's being done including running a self-tapper in some situations. We are reviewing all of our installations for a best practice that we can use across the board.
An FYI: The ducts that I have accessed on my 2011 Flagstaff Fifth Wheel are secured with tape and one tapping screw.
Terry/Bernadette
Lily the Yorkie
2015 Dodge Ram Sport 1500
2015 Crossroads Zinger ZT28BH
Rugged Brown is offline   Reply With Quote
Old 12-06-2011, 01:31 PM   #12
CLASS "A" Senior Member
cfsoistman's Avatar
I've been doing residential HVAC for over 35 years and common practice is tape & at least 2 screws. One county in our area requires 3 screws. In some cases a panduit strap (zip-tie) is used as well. In most cases duct-tape has been replaced with aluminum tape. Glad to hear it's being looked into for a common solution. When standards are established the grey areas disappear.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
cfsoistman is online now   Reply With Quote
Old 12-06-2011, 01:34 PM   #13
Commercial Member
I recognize the word duct tape was used by a poster but we use aluminum tape on all of these applications.
A zip tie seems too easy. Does this hold up long term with the heat?
RV Guy is offline   Reply With Quote
Old 12-06-2011, 02:08 PM   #14
cfsoistman's Avatar
The type of zip-tie I'm talking about is about 3/8" wide [other use is riot control handcuffs], not the type used for electrical work. The screws and tape are the most commonly used and the reliability is the best.
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 12-06-2011, 02:38 PM   #15
Commercial Member
Got it - I could probably use the zip ties for the riot control but maybe not a good idea for the heat duct .
Thanks for your input
Old 12-06-2011, 06:28 PM   #16
Vols's Avatar
i own a HVAC company and this is the first thing I looked at after getting new RV home. I put a panduit strap on each duct run.
Vols is offline   Reply With Quote
Old 02-16-2012, 08:42 PM   #17
LKicklight's Avatar
Wheel Lugs
Have your people checked into the wheel hub/lug nut problem that I am having on my 270 Crusader? Sent photographs in to RS at corporate and Three Way Camper here in Marietta. GA. Would like an answer from someone soon...cannot take it out like it is..thanks RV Guy
LKicklight is offline   Reply With Quote
Old 02-16-2012, 10:04 PM   #18
Commercial Member
Yes, there are several people on this. I'm pretty sure I know the answer but I'm getting confirmation from our vendor first before posting an answer. Needless to say, there are alot of folks here (and a couple of self-professed experts) waiting for an answer and we understand the anxiety involved with the appearance of the situation.
PTM
Old 02-17-2012, 04:08 AM   #19
Witch Doctor's Avatar
I have done HVAC for 20 years, If you are using flex pipe, Take a plastic tie rap around and pull it tight unless you have the tool to do it automatically (makes it a lot tighter). Then put a 1/4" self tapping drive screw though the tie and into the metal duct then a good grade of duct tape around the connection. Either household or RV HVAC, it's all the same recommend procedure. Hope this helps, safe and warm wishes.
Old 02-17-2012, 07:27 AM   #20
Oakman's Avatar
OK, Iím impressed. A manufacturer rep that admits to a problem and works to resolve the issue instead of posting a bunch of BS and excuses as to how this couldnít have happened during the build of the trailer.
We're in the market for a new trailer and I wish I could say that I would be considering the purchase of a Prime Time fifth wheel but the nearest dealer is over 250 miles away.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
