Old 05-20-2019, 08:43 PM   #1
Wallpaper for patching?
Anyone know where I can find some replacement wallpaper? When the factory installed the curtain valances they drilled multiple test holes apparently. We removed the valances and the holes are hideous. ??
2020 Flagstaff Classic 832IKBS
2011 F250 Lariat Crew, 2WD, 6.7L,
3:31, Husky Centerline
Reeves is offline   Reply With Quote
Old 05-20-2019, 09:17 PM   #2
Iwannacamp's Avatar
Closet down low under shelf? Maybe peel a bit.
I found a link to a place in Indiana. I will try to find it.
2017 Puma 297RLSS
Old 05-20-2019, 09:21 PM   #3
Iwannacamp's Avatar
Here it is...if the dealer canít get it for you. I think this is supplies some of it.
https://sites.google.com/a/qepdesign.com/qepdesign/
2017 Puma 297RLSS
Old 05-20-2019, 09:28 PM   #4
Thanks! I'll let you know how it goes.
Old 05-21-2019, 08:32 PM   #5
I had the same problem on my Coachman Freedom Express after I had to replace my fire extinguisher and had to relocate it. I called the factory and talked to customer service. They sent me about 20 feet of the wall paper tape. Matched perfectly.
stevegotl is offline   Reply With Quote
Old 05-26-2019, 04:19 PM   #6
May or my not work for you but what I have done is to find a cabinet with wallpaper behind where the back of the cabinet is open, make an outline cut with a knife, peel off the paper inside the cut, then glue it over the hole matching the pattern.
Another method is to remove a cover plate on a wall switch. Use a hole punch to make a small round cut, peel out that piece and glue it over a screw hole.
Harold41 is offline   Reply With Quote
Old 05-26-2019, 04:51 PM   #7
bikendan's Avatar
Have you contacted PrimeTime yet? I've had good luck with them.
Equalizer WDH
