Old 10-30-2014, 05:07 PM   #11
irishrv's Avatar
Curious were you using a pressure regulator on the hose to flusher? Not saying that caused it but interesting to know. I've argued for thier use on that flusher.
2014 295rst champ te
2009 2500hd GMC d/a
2014 295rst TE Champagne
09 GMC 2500HD D/A
irishrv is offline   Reply With Quote
Old 10-30-2014, 05:09 PM   #12
Toy-aholic
All water to my trailer is regulated
2005 GMC Sierra 3500 SLT DRW 6.6 D/A
2013 Crusader 335BHS TE
EXGMTech is offline   Reply With Quote
Old 10-31-2014, 03:16 AM   #13
irishrv's Avatar
Had one fail in my cougar but pretty sure it was because I forgot to winterize the black tank flusher. Yes they are a hazard for sure.
2009 2500hd GMC d/a
09 GMC 2500HD D/A
Old 10-31-2014, 03:34 AM   #14
Witch Doctor's Avatar
FR probably use's the same one on all there models which would be my guess. How did you ever find it? Thanks I'm going to look around and see If I can spot my location.
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 10-31-2014, 08:55 AM   #15
rracer5's Avatar
2009 2500hd GMC d/a
I never thought about winterizing the black tank flusher!!! Guess I got lucky last winter!!!
"PT Crew Members Since 9/2010"[/I][/B]
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
Old 10-31-2014, 09:05 AM   #16
TURBS's Avatar
I'm not sure why you'd have to winterize the black take flusher.
Never have in mine.
It's open on the tank end and unless it's plugged the water would just run out.
Right?
Turbs
Old 10-31-2014, 09:08 AM   #17
Windywest's Avatar
Ours failed this summer, water running out of the bathroom vanity. I managed to pull the water lines down, and replaced the valve with a 75 cent 1\2 inch fitting from our hardware store.
Cheers from Alberta Canada
2011 Flagstaff 8526RLWS 5th Wheel
2011 Ford F250 4X4 Crewcab Superduty 6.7L Diesel
B&W 3300 Hitch for Ford 5th Wheel Prep package
Windywest is offline   Reply With Quote
Old 10-31-2014, 01:43 PM   #18
Toy-aholic
hmmm not proud of how I found it but, first I partially removed my water htr to see where the flush hose amongst 35 other hoses went....pulled the fireplace, then pulled cable connection plates in the ent. ctr......and wala found it there opposite the shower control panel.
Old 10-31-2014, 02:18 PM   #19
irishrv's Avatar
Warning/FYI to all Crusader 335BHS owners
Never have in mine.
Right?
Turbs
If it has a vacum valve water will sit in that and freeze and crack it and the pipe that goes up to the valve.
2009 2500hd GMC d/a
09 GMC 2500HD D/A
Old 10-31-2014, 02:42 PM   #20
I'm having trouble seeing the point of a vacuum valve. The black tank is vented- it shouldn't be able to pull vacuum, right? A back-flow prevention valve I could see.
crusader
