Old 11-04-2014, 05:29 AM   #51
Anybody know where this thing is on a 3170?
2015 Sunseeker 3170ds
TakeItEasy is offline   Reply With Quote
Old 11-07-2014, 04:50 AM   #52
Witch Doctor's Avatar
I tried to find that valve on my 8289WS, I can't find it? I even took apart the shower looking for it, be damned if I can find it. Anyone know if there is one or where it is located on my model?
Coachmen M/H
Concord
2018 / 300 DSC
Old 11-07-2014, 05:27 AM   #53
Damn Glen I had to climb down to tell you to look near where the O/S is located for the valve! Youroo!!
Old 11-07-2014, 07:26 AM   #54
It's not there for sure I heard some gurgling when blowing out that line behind the shower enclosure area No way to get to it if that's where it's located took off the fixured and looked. I added juice to the black flush line 1/2 gal through your way of using the O/S shower to my black water flush line, Maybe if we have the valve it might help to protect it. Now get back in the treestand, Getting tired of SPAM..... and keep your eyes open.
Coachmen M/H
Concord
2018 / 300 DSC
Old 11-07-2014, 04:46 PM   #55
BBBlue's Avatar
Does anyone know if there is a vacuum breaker installed on the Sanibel 3500 units? If so, where is it located??
BTCM(SW) Ret USN
2013 Sanibel 3500
2013 Ram Truck 3500 Laramie Longhorn Dually
2017 Days camping-190
2018 Days camping-66
BBBlue is offline   Reply With Quote
Old 11-22-2014, 02:29 PM   #56
Found the vaccum break for the black tank flush on the 3170ds. It is accesible via the cabinet in the bathroom. I wish they would have moved the outside conection over a little so you could hook a hose to the black tank flush and latched open the door for the dump valves at the same time.
Old 11-24-2014, 06:12 PM   #57
07 ThunderRoad's Avatar
It is located behind the shower handle set. On our 3600 Sanibel but dealer cut the closet wall out and installed access to it from the entry closet
2013 Sanibel 3600 5th, 2007Dodge 2500 Cummins Turbo Diesel, 2WD, 4.10gears, Banks equipped, 18" factory rims
07 ThunderRoad is offline   Reply With Quote
Old 11-25-2014, 07:50 AM   #58
BBBlue's Avatar
Thanks for the reply. I will have to check mine out, when I get a chance. Have you had any issues with the breaker on your unit?
BTCM(SW) Ret USN
2013 Sanibel 3500
Old 11-25-2014, 06:39 PM   #59
Yes. It was pouring water out the first time I used it. Flooded the basement of the coach. I called Prime Time. They told me it was located in the wall, at the shower handles, on the 3500 & the 3600 coaches.
Old 11-25-2014, 06:48 PM   #60
BBBlue's Avatar
Did you replace it with same or upgrade part??
BTCM(SW) Ret USN
2013 Sanibel 3500
crusader
