Old 02-27-2015, 09:56 PM   #71
I had this happen on my brand new Tracer 230BFS, the first time out. The dealer replaced it with the same part and winterized the unit for the first time. They did not winterized the black flush. Hope all is well as there was quite a flood inside and dripping down from right next to the wall under the trailer. Cold weather was already upon us, so I hope there is no water frozen in the underbelly. Reason for the failure - two bugs lodged inside the valve.
AbdRahim is online now   Reply With Quote
Old 02-27-2015, 10:13 PM   #72
It is under & behind the lavatory in the bathroom in my Flagstaff.
Old 02-28-2015, 12:18 AM   #73
gashog's Avatar
This thread is very informative to say the least. I never gave it a second thought about winterizing the BWF lines (first time having a BWF). My back flow vacuum breaker is located under the bathroom vanity and happens to be the cheap black plastic one (it will be getting replaced). The water lines going to and from it are not PEX, they are that nylon braided hose. I really doubt this type of hose would actually break and/or split if some water was still in them and it froze??? right or wrong? Just a little worried, it's after midnight about 16 degree F and I ran out and looked and took pictures....
ID:	70395   Click image for larger version
2015 Rockwood Windjammer 3029W Diamond Package
2014 RAM 2500 Laramie Longhorn 4 x 4
6.4 Hemi 410 HP, 410 Rear Axle
gashog is offline   Reply With Quote
Old 02-28-2015, 08:50 AM   #74
gashog's Avatar
What would be wrong with installing this one? Just add threaded nipples.
Amazon.com: Cash Acme 17383-0000 V-101 1/2-Inch Brass Anti-Siphon Vacuum Breaker: Home Improvement
Old 03-01-2015, 07:38 PM   #75
Windywest's Avatar
I still don't know what's wrong with just getting rid of the entire fitting and just bypass it with a 50 cent coupler. I did last year and haven't had any issues, black flush works the same as ever.
Cheers from Alberta Canada
2011 Flagstaff 8526RLWS 5th Wheel
2011 Ford F250 4X4 Crewcab Superduty 6.7L Diesel
B&W 3300 Hitch for Ford 5th Wheel Prep package
Windywest is offline   Reply With Quote
Old 03-01-2015, 07:45 PM   #76
jtstromsburg's Avatar
The point of the device is to prevent black water from inadvertently coming back from your black tank, thru your black water rinse hose, and finally possibly back into the campground or whatever freshwater supply you are hooked up to. If you find it necessary to remove, please make sure you add one at the hookup point of your trailer.
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is offline   Reply With Quote
Old 03-01-2015, 07:56 PM   #77
Windywest's Avatar
I don't leave my bwf connected until I want to flush, even then I use a Y Connector so it's impossible for any flow back into the water supply.
Old 03-01-2015, 08:00 PM   #78
Just put a shut off valve on the hose as it goes into the flush connection and shut it off there while the water is still flowing.
I use a black pocket hose strictly for the black tank flush.
Old 03-01-2015, 09:53 PM   #79
Windywest's Avatar
That's exactly what I do. The Y hose connector has 2 shutoffs, and when I use the bwf, I shut it off while the water is running. Also a separate hose for the bwf, even a different color so never any confusion.
Old 03-02-2015, 05:30 PM   #80
gashog's Avatar
I decided that the next time I winterize the pink antifreeze will be pumped through BWF via the outside shower. Went to Lowe's and got a 3/4 Male Hose x 1/2" MIP, threaded right on the shower hose. $4.39
ID:	70569   Click image for larger version
crusader
