Old 01-03-2015, 05:20 PM   #1
washer/dryer combo
We have a 2012 Primetime Crusader and want to buy a washer dryer combo. Has anyone installed a w/d in your Crusader? Seems like the opening for it is too small. Also what is the make and model that fits?
dogmother53 is offline   Reply With Quote
Old 01-03-2015, 08:20 PM   #2
rracer5's Avatar
Splendide¬ģ Laundry Centers - Splendide in RV applications
These are specifically designed for RV's. But, I would measure the floor to ceiling distance of your Crusader. Not sure if a stackable combo will fit.
"PT Crew Members Since 9/2010"[/I][/B]
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
Old 01-07-2015, 07:25 AM   #3
wmcclay's Avatar
Iam going to assume you are plumbed for it. You will want to vent it outside. If wall is not marked call PT and get vent position. If its plumbed a splendide will fit. They work great if you do small loads. We could not find a stack set that would work in ours.
Wayne
Wayne, Donna and Moab
2016 Ford S/D Platinum
2013 Sanibel 3500
Honda 3000 si
4 6 volt batterys
wmcclay is offline   Reply With Quote
Old 03-14-2015, 08:17 PM   #4
Wayne, do you have any suggestions for actually installing the dryer vent?
greenfam09 is offline   Reply With Quote
Old 03-16-2015, 08:53 AM   #5
wmcclay's Avatar
Measure to see if it will fit through door. Call customer service for location of vent if not marked. Drill 1/4 inch hole through side wall. Use a hole saw of the correct size from inside for wall and from the outside for outside wall. (cleaner that way) ENJOY your install. Its great on long trips, We do not like using Laundromats.
Good Luck
2013 Sanibel 3500
Honda 3000 si
4 6 volt batterys
