Old 08-11-2017, 11:59 PM   #1
Water coming out overflow
2015 Primetine avenger ATI:
We are at a new park and we're told they have really high water pressure here. We do have a proper pressure valve at the faucet but we noticed after a while of being hooked to cut water, the fresh water tank was having water come out the over flow. I turned off the city water and drained the fresh tank. While the plug to the fresh tank was pulled, I turned the city water back on and noticed the water again started draining out of the fresh water drain... What's going on here? Is this because this campground has such high pressure and this is a safery feature on the avenger? I've never had this problem but it seems like the city water is back flowing into the fresh water tank until the point it overflows. Plz help, thanks
rhino_160 is offline   Reply With Quote
Old 08-12-2017, 01:53 PM   #2
rracer5's Avatar
Your check valve in the water pump may be sticking/stuck thus allowing water to backflow through the pump into the FW tank.
Try filling the FW tank, turn off the CG water supply and use just the pump for a day or so. This may exercise the valve enough to free it up & start working properly.
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
Old 08-13-2017, 03:14 PM   #3
Yep, water pump check valve.
You can cycle the pump a few times or do what I did and remove the 6 side screws on the pump and clean the inside up and grease the rubber parts before reassembly.
2012 Prime Time Crusader 320RLT
2006 Weekend Warrior LE 3300
DWRAT is offline   Reply With Quote
water
