Old 06-03-2013, 05:32 PM   #1
mdalb20's Avatar
Water flow
I apologize up front if this question has been answered. I did do a search but perhaps I am not phrasing it properly. The water pressure on my Crusader 295RSt seems ok with full pressure in the bathroom sink but in the shower and at the kitchen sink it seems awfully low. I removed the regulator I had attached to the hose outside but not much different. Am I missing something?
mdalb20 is offline   Reply With Quote
Old 06-03-2013, 05:38 PM   #2
Does it have one of those little water saver discs with the tiny hole in the discharge?
Timtation is offline   Reply With Quote
Old 06-03-2013, 05:44 PM   #3
mdalb20's Avatar
In the faucet itself? I will check that out. Thanks
Old 06-03-2013, 06:19 PM   #4
Take the end off the faucet spout and remove the disc and clean the debris out of the remaining pcs. Do the same with the shower head.
Oh, forgot to tell you to throw the discs in the garbage can.
Old 06-03-2013, 07:48 PM   #5
WestCoastRV'er's Avatar
This is a common issue. Remove the screen on the faucet and clean. I clean mine at least twice a year.
2011 2902ss Rockwood Ultralight
2008 Grand Cherokee 3.0L Diesel (255 hp @ 2900 rpm / 430 lb-ft @ 1,400-2,800 rpm)
3P ProPride Hitch
RV Mods
Wandering RV Life
WestCoastRV'er is offline   Reply With Quote
Old 06-04-2013, 04:56 AM   #6
mdalb20's Avatar
Thanks for the tips. It has been this way since we picked it up new so not sure what could be clogged but I like the idea of taking them and tossing them out!
Old 06-04-2013, 05:12 AM   #7
Toy-aholic
I had a similar issue on my brand new Crusader, turned out the screen on my pressure reg was clogged with muck.
2005 GMC Sierra 3500 SLT DRW 6.6 D/A
2013 Crusader 335BHS TE
EXGMTech is offline   Reply With Quote
Old 06-04-2013, 07:33 AM   #8
I found small foam pellets from the insulation in mine about a week after getting our trailer.
I also found that my pressure was low after replacing our filter. After a day it was back to normal.
3P ProPride Hitch
RV Mods
Wandering RV Life
Old 06-04-2013, 07:55 AM   #9
Herk7769's Avatar
This is also a common complaint when folks drain the hot water heater through the low point drains instead of bypassing and removing the anode.
Bits of anode material and calcium chunks get swept into the tubing and when you do finally pressurize the system, that junk gets pushed everywhere. (Faucets, shower head and flush valve)
HAM CALLSIGN - KC3FFW
Old 06-04-2013, 05:26 PM   #10
mdalb20's Avatar
Thanks all. I will check it this weekend.
Old 06-04-2013, 08:36 PM   #11
MovinSue
MovinSue's Avatar
I also had low pressure and removed my pressure regulator. When I did, I observed an accumulation of gunk-la-dytes (technical term for debris of unknown origin) in the washer filter and in the pressure regulator. Cleaned everything out and reattached without pressure regulator and now water pressure is excellent. I do feel a little uncomfortable without the pressure regulator attached...
"Some say that wine improves with age...I say that age improves with wine"
2013 Lacrosse 323RST TT
Towing Cassie the Dog, a privileged Bichon frise
Winters in FL--Summers in Northern CA
MovinSue is offline   Reply With Quote
