Old 09-11-2012, 10:01 PM   #1
Water Heater Bypass Valve Location
I would like to winterize our Tracer 2670 to prepare it for the Michigan winter. The directions in the owner manual seem easy to follow, except I don't know where the water heater bypass valves are located or if the water heater is even equipped with them. Any info is appreciated.
2014 F150, Supercrew, 3.5L Eco-Boost, 3.73, Max Tow
2012 Prime Time Tracer 2670 BHS
TravelTracer is offline   Reply With Quote
Old 09-11-2012, 10:14 PM   #2
TURBS's Avatar
It's equipped with them and there directly behind the Hw heater.
Old 09-11-2012, 10:48 PM   #3
Is there a removeable panel? I'll have to take a closer look when I'm able to get back out to the trailer.
Old 09-12-2012, 05:38 AM   #4
TURBS's Avatar
Sorry yes there most likely is a removable panel in a cabinet or behind a false door,
Old 09-12-2012, 07:04 AM   #5
f1100turbo...Thanks for the info. I should be able to find the valves now.
Old 09-12-2012, 07:18 AM   #6
TURBS's Avatar
Just look on the inside directly behind where Hw heater is on the outside.
Turbs
Old 09-12-2012, 07:57 AM   #7
CampingQueen
Had the exact same question.... and the same answer! They were just behind the water heater behind a little tiny cabinet door.
2012 Flagstaff V-lite 30 WTBS
2011 Ford Expedition
4 kids and a hubby & never enough time to camp!
2011: 17 nights 2012: 26 nights 2013: 46 2014: 20 2015: 16
arlee453 is offline   Reply With Quote
Old 09-13-2012, 10:48 PM   #8
f1100turbo and arlee453...Thanks! I was able to locate the valves....right where you said they would be.
