Old 05-24-2014, 06:14 AM   #11
Herk7769's Avatar
Is that water heater gas only?
I only see two red wires going to the gas solenoid and a black going to the DSI.
I am not as familiar with Atwood water heaters, but there should be an element somewhere if it is dual powered.
No element I can see. What is the model number?
HAM CALLSIGN - KC3FFW
Old 05-24-2014, 06:21 AM   #12
wmtire's Avatar
Since you have the Atwood brand name heater, you might start with the owners manual from our library.
Forest River Forums - Downloads - Water Heater - Atwood Water Heaters
Pagr 4 tells about the electric heating element and that there is a switch on the BACK of the heater, as well as a resettable hi-limit switch you can press with a pencil or non-metallic object to try. It has a pic of the location.
You said the dealer winterized it for you. Did you manually verify there was water inside the heater before turning it on by electric, by opening the pressure valve on the front of the heater.
If not, then there may have not been water in the heater, and the element is burnt up.
However you stated it was working on gas, so I am assuming you are getting hot water, thus the bypass valves have been set for summer use, and are not still in winter mode (thus the water bypassing the heater).
If the bypass valve is still in winter mode, you cannot verify there is water in the heater just by turning on the hot water taps inside your trailer........................... since the purpose of the valve(s) is to bypass the heater, thus the cold water line is now merged into the hot water line................so you will always get water from the hot water tap, it'll just be from the cold water line.
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 05-24-2014, 06:32 AM   #13
Herk7769's Avatar
Sorry to be so ignorant of the Atwood system.
The manual says the electrical side stuff is on the "other" side of the water heater.
"In 2003, Atwood relocated the Switch, Thermostat and ECO that was installed on the back of combination 6 and 10 gallon Gas/Electric Water Heaters. A double switch is now located inside the RV for convenience and a joint ECO and T-Stat is located on the gas side of the water heater. This leaves only the relay and heating element on the backside of the water heater."
If you had that AC power switch on, without water in the tank, then you have fried the element for sure.
Verify you have 120 VAC at the element and if so just replace it with the correct part.
Old 05-24-2014, 06:43 AM   #14
wmtire's Avatar
Here is some more links to great troubleshooting manuals, with lots of diagrams.
Atwood Water Heater Troubleshooting
http://hometips.me/Mar/Atwood-Water-...ice-manual.pdf
Old 05-24-2014, 08:47 AM   #15
RollingDownTheHighway's Avatar
here is the inside
Name:	ImageUploadedByForest River Forums1400939243.503708.jpg
2013 Prime Time Tracer 3200BHT
2016 Chevy 3500 CC, DRW (aka: bigbootyjudy)
Ribs in the smoker and Whiskey in hand
RollingDownTheHighway is offline   Reply With Quote
Old 05-24-2014, 04:06 PM   #16
Herk7769's Avatar
The element you need to change is inside that black box, I am thinking.
Not much room to work around those pipes though.
I did some more reading and the high limit is "dual use" and on the outside; so if the gas works fine, that is OK.
heater, propane, water, water heater
