Old 08-19-2012, 12:07 AM   #1
wdmeans's Avatar
Water Heater Woes
We have a 2013 Crusader 325RES 5th wheel. We have had it since June 30th. Our water heater has been working beautifully until last night. We had no hot water. We have it on electric mode only as it provides enough hot water for our needs. Sometimes we will put it on propane prior to multiple showers. We turned the electric button off overnight. This morning, we turned the electric button to the water heater on, but it did not seem to do anything. Finally turned on the propane button, waited a bit and then had hot water. We checked the 2amp fuse on the circuit board outside--it is fine. Checked fuses in the converter box inside--all ok. My DH said he heard a "hum" outside at the circuit board when I turned the electric button on again. We waited for quite a while and tried the hot water--nope! Had to turn the propane button on again to do dishes. HELP!
Prime Time Crusader 325RES
2007 Chevy Silverado 6.6L Turbo Diesel
Will and I are loving life and traveling with our two four-legged "children"!
wdmeans is offline   Reply With Quote
Old 08-19-2012, 12:16 AM   #2
papap's Avatar
element in tank may have gone out.
2016 Forester 3171DS
Work 28 and 28 around the world.
Camp every chance we get
papap is offline   Reply With Quote
Old 08-19-2012, 12:23 AM   #3
wdmeans's Avatar
Papap--even tho it is only a month and a half old???
Old 08-19-2012, 07:40 AM   #4
Fuses or circuit breaker? The electric hotwater heater is controlled by a circuit breaker not a fuse....Did you check that?
2011 Lacrosse 318BHS Touring Edition
2012 Ford F150 SupCrew 4x4 XLT 6.5' Max Tow
padave65 is offline   Reply With Quote
Old 08-19-2012, 07:45 AM   #5
Herk7769's Avatar
Times 2.
Reset it anyway. It may "look" good and still be tripped.
HAM CALLSIGN - KC3FFW
Old 08-19-2012, 11:10 AM   #6
wdmeans's Avatar
We did check the circuit breaker--turned it off and then back on again. Also, there is a 2 amp fuse in the circuit board outside--not sure what it is for, but DH checked it and it is good. I am thinking Papap is probably right and it is the heating element in the tank. Not sure how to get to it and we don't really want to mess with it--back to service it goes!
So many problems, so little time!
Old 08-19-2012, 11:23 AM   #7
AKA Bluebird
dimurrrw's Avatar
Send a message via Yahoo to dimurrrw
Did you push the reset button?
dimurrrw is offline   Reply With Quote
Old 08-19-2012, 11:36 AM   #8
papap's Avatar
Do you have a volt meter?
Old 08-19-2012, 11:49 AM   #9
wdmeans's Avatar
Where would the reset button be? There is a red rectangle button (light) on the control panel (with the elec/gas buttons for the water heater. DH pushed on it some and it went in a bit, but wouldn't come back out again and we have never seen it light up.
Old 08-19-2012, 11:54 AM   #10
wdmeans's Avatar
DH says he has an amp meter
