Old 02-22-2014, 02:08 PM   #1
Jsaso845's Avatar
Water pump hose
Lacrosse 318bhs- We are out on first trip and noticed some water leaking from under sink area.. Started looking as discovered a water hose which is attached to water pump, other end of hose is aimlessly pointed towards bottom of sink and not attached to anything and is source of leak. Any suggestions?? Dealer said they'd call me back but that was 3 hrs ago..[ATTACH]46628[/ATTACH
Name:	ImageUploadedByForest River Forums1393099680.221013.jpg
Jsaso845 is offline   Reply With Quote
Old 02-22-2014, 02:27 PM   #2
If I'm not mistaken this is a feed hose for antifreeze. I own the same trailer and checked mine, but hard to tell by your picture.
Drmstx62 is offline   Reply With Quote
Old 02-22-2014, 02:29 PM   #3
Mac 57's Avatar
I maybe wrong, but to me it looks like it might be a hose that would be used to siphon anti freeze into the system for winterization. There is a valve there to direct the flow to or from the pump. The valve may not be positioned correctly allowing the leakage.
Hope it is something this simple.
Mac 57 is offline   Reply With Quote
Old 02-22-2014, 02:30 PM   #4
Mac 57's Avatar
Darn Late Again
Old 02-23-2014, 08:54 PM   #5
Jsaso845's Avatar
@Mac 57 @Drmstx62 Thank you both, service called and you guys were correct. Appreciate it!!
Old 02-23-2014, 09:44 PM   #6
rracer5's Avatar
If you ever need to winterize your unit, you'll come to love that hose !!
"PT Crew Members Since 9/2010"[/I][/B]
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
Old 02-23-2014, 09:51 PM   #7
Jsaso845's Avatar
We're out in Southern California and it was 79 today at the lake... Prob not. A lot of winterization goin on here!! But we sure could use some wet stuff on the ground
Old 02-23-2014, 09:54 PM   #8
rracer5's Avatar
That's why I said "if". Wish I knew how to send you some of this snow and moisture we've had here lately. I know you could use it.
2014 Sanibel 3250
pump, water, water pump
