Old 10-11-2017, 05:05 PM   #1
Water Pump Location?
Hello everyone. I just bought a 2013 Avenger 23FBS. I filled up the water tank, bleed the lines, filled water heater. But when I turn on the pump it does not shut off. I don't see and leaks. So I was going to look at the pump, but I can not find it.
I can hear it toward the back in the bathroom near the switch, but cannot see where there is an access panel to the pump? Any help is appreciated
terrydunn is offline   Reply With Quote
Old 10-11-2017, 11:51 PM   #2
Platokidd's Avatar
Have you tried looking here (X)could be behind a cabinet wall board
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
Seasonal
R.I.P. Luke the campin dog
Old 10-12-2017, 05:03 AM   #3
071567's Avatar
Could it be under the bed
071567 is offline   Reply With Quote
Old 10-16-2017, 03:21 PM   #4
Platokidd
I believe your right, it seems to be under the lower left side. There doesn't appear to be a way to access it. Seems very strange they would not have an access panel no?
cat, location, pump, water, water pump
